Pallets in fields
   / Pallets in fields #1,961
Still following potential locations for Where In the World is Steve?
If Steve is following his idol Euler's path in life, he would have traveled from Switzerland to St. Petersburg, Russia. It's a big town to search. There was a local news story that could have been Steve:
It seems some tourist was gathering coins in the fountain. Language is a barrier of course, but I understood the tourist was yelling, "Currency must be in circulation to maintain bank liquidity!" It sure sounds like an economist's meltdown. Could have been the vodka. As you can see, he was dragged away. Hopefully Steve isn't residing in some Siberian gulag now.
I do appreciate the guidance: "Find the girls and Steve will be there." To that end, I will be checking out the renowned St. Petersburg body painting scene next.
That photo was taken during summertime in St. Pete. It is colder than a witches ta ta's over there now. That couldn't have been Steve.
   / Pallets in fields #1,963
Dave, being an A hole does not look good on you
Just saying :thumbdown:
It's closer to the truth to say "You're the one not looking to good right now :eek:".
You've embarrassed yourself....just sayin....:dance1:
   / Pallets in fields #1,964
But has anyone actually come up with the answer to the important ponderings in this thread? :confused3: And why won't winter leave and do it quickly?
   / Pallets in fields #1,965
OK THAT'S IT! I GOT IT....I FIGURED IT OUT.
Steve knew exactly why the pallets were in the field. He knew and so did Zelda. Steve wanted the wormhole all to himself, that's why he invented the fictitious Zelda from California who has nothing to do with anything, if she exists at all.
The real Zelda was about to spill some very telling things about Steve when she herself went into the abyss.
Steve is in Tasmania, he traveled there using the blackhole..... on his way, he altered history...... is now wearing spike heels and lost a lot of weight....
Two questions:
1. Wagtail, Have you run into Steve during his visit to Tasmania?
2. Robert, Did your recent extended absence have anything to do with the worm hole?
   / Pallets in fields #1,966
Two questions:
Consider that WAGTAIL may be an alter ego created by Steve. My absence was do to this thread, not specifically to the blackhole.
   / Pallets in fields #1,967
Yes the answer has been found
Your current weahter conditions will change.
   / Pallets in fields #1,968
How do we know you are you? We have a partial blind monkey and a gang of horses to believe all this....And one Horse is Mooning us!!!
   / Pallets in fields #1,969
Would a different avatar really matter?
I can't answer your question. I can only question your answer.
   / Pallets in fields #1,970
Just making sure you are you. You are aren't you?
2257 (A58376)
2257 (A58376)
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
POLY BARREL & WELL TANK (A58374)
POLY BARREL & WELL...
2011 DOOSAN G25KW GENERATOR (A58216)
2011 DOOSAN G25KW...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
