Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,762
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Most motors today run around 85% efficiency... at least the ones I read specs on.
The current method of determining hp is what is referred to as "locked rotor" rating. As previously stated. The point where the voltage starts to fall off drastically and the current spikes....bam they get max voltage and max current (for a split second) and multiplying and all get hp. Has nothing to do with real usable hp. Just more marketing hype to charge more and supply less.
On comparing weights, I have a 1/3 hp motor my grand dad gave me when I was young. It is about 12" in diameter and weighs about 50#. Motors have come a long way and not all are made from the same components, especially any magnetic parts.
The fact that I see two humps on top of the motor tells me it is a capacitor start....aka starts under load easily and capacitor run, meaning it balances the inductance for a PF of around 1 while supplying high current. Being compressor rated also tells me that the motor is either series or compound wound which deliver high torque.
Again, the high pressure/high current demand is just a spike for just a second and the normal stress on the motor is otherwise minimal. Idle running current is just a fraction of full load current so cost to run is nothing.
Running a 3 hp motor would be akin to about 2.2 kW if running at full load. Ok so you leave the motor running at full load current for a full hour and at the 11 cents per kWH I pay for electricity, that would have cost me about 2 bits (25c). Man that's going to break the bank! Ha! But it doesn't run at rated current for the full hour, but just a second per log. So it won't cost that much. Gimme a break.
Mark
Mark
