Front 3-point linkage for a JD 855
/ Front 3-point linkage for a JD 855 #1
Was there a front linkage made for the 855?
I am hoping to install one to mount a transport box on the front of my tractor.
Thanks in advance.
OK. Following extensive web searches, I finally found a reference to a JD model BM16492 for the 55 series. Surprised I got no responses here.. :-(
/ Front 3-point linkage for a JD 855 #3
I don't believe that's a 3pt but instead a mount for attaching a snow blade, snow blower or sweeper.
You may well be right. It's the only item I could find that offered a front of tractor mounting for attachments, and got no other suggestions.
The photos I found on the 'net certainly seemed to have a 3-point attachment facility.
/ Front 3-point linkage for a JD 855 #5
Sureley european companies like opico or zuidberg will make them to order for any tractor . There seem to be lots for sale for all other brands of this size except deere ?
0.8 T Zuidberg Front Linkage
/ Front 3-point linkage for a JD 855 #6
I should think the best "transport box" for your tractor would be a loader. I've referred to mine as a diesel powered wheelbarrow on occasion.
That's certainly a possibility if I can find a used one. I'm afraid I wouldnt have the budget for the price of the new one.
Agreed. However, there are other implements I would like to mount up front also.
/ Front 3-point linkage for a JD 855 #9
The original Deere front mount has the front pto shaft attached to it also, this will be a problem for you if your "other" implements require it. The current Deere's front attachment kit is more along the lines of a 3 point setup.
Also, with the "old" style mount, it has to be removed for the mid-mount mower.
Ed
Ed
Hi Ed
Would you happen to know what part numbers you are referring to? I'd like to Google the alternatives. Thanks. Tom
/ Front 3-point linkage for a JD 855 #11
Tom, I'll dig up the manual for my front mount kit, it'll have the part number on it.
Ed
/ Front 3-point linkage for a JD 855 #13
Here you are: BM16492 is the front attachment kit, BM16494 is the front pto mount kit.
I took a few pics of it for you....hope it helps.
Ed
/ Front 3-point linkage for a JD 855 #14
Ed
that's not a front 3pt setup.... that is the front Quick Attach setup.
/ Front 3-point linkage for a JD 855 #15
You are correct, he asked what was available, to my knowledge that's it......
Ed
Ed
Thanks for the pics Ed. Yeah, that's the part number I have been looking at. As Mechanos points out it is more of a quick attach than a 3 point linkage per se. I'm looking around to see what others may have done to cater for a top linkage, as I assume at this stage the bottom points would be catered for by the QA mechanism.
Thanks again- Much appreciated. Not easy here in Ireland to get info on these great machines..
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2022 EZ-GO ELITE...
Wooden Chair (A64557)
Barrel (A64557)
Barrel (A64557)
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
More info coming soon (A61574)
More info coming...
