Engine Drive Welders
/ Engine Drive Welders #1
Sprockmonster
Bethel, CT
1952 ford 8n
Hey I was wondering what anyone could tell me about engine drive welders. I know I would want at least 250-300 amp and preferably operating ac/dc+.
/ Engine Drive Welders #2
I've got an old Lincoln G8000. It's 250 amps ac/dc. I also use it for backup power (8000) watts. It's served me well.
It has a 16hp Briggs Vanguard uses about a gallon an hour under full load.
John
Preferably used, I would only be using it for convenience around the yarn because I have a very small shop and one 220 hookup. I don't know whether gas or diesel; whichever is more cost-effective/efficient in the long-run. As for price, as cheap as possible, as long its in goodoperating condition.
/ Engine Drive Welders #5
There are a few guys over on Welding Web who are having trouble with their Miller Trailblazers.
A good buddy of mine as well as member here WelderMike have Lincoln 305-Gs. I've run my buddies very nice machine! Member here Arcweld just started a thread a couple weeks ago about his neighbor having trouble with the engine in his 305-G, so buying a used 305-G might be the way to go.
Thanks I'll check them out.
/ Engine Drive Welders #7
Not too many AC/DC models but there are a few. Diesel would be more money. Really need some more information on what you want to do, like do you want to be able to MIG and stick or do you want a generator as well.
I would like to be able to mig and stick... a generator would be even better...:drink:
/ Engine Drive Welders #9
If you don't find a deal on an engine drive you can always buy a generator and run whatever welder you want off that. Do you really need 250-300 amps? 200 amps DC should be enough to run 5/32 rod. That will weld some pretty big stuff. Really 1/8" rod has enough heat to weld just about any thickness with multiple passes as long as you have enough duty cycle that it's not tedious.
How would I be able to make my welder capable of riding on top of my truck with the generator.
/ Engine Drive Welders #11
You need a big generator to power a welder so you are better off getting a combo welder/generator. It all depends on your budget. If you want to spend less than $1000, it's pretty slim picking for something that will do stick, MIG and have a good size generator.
/ Engine Drive Welders #13
The gxt or gtx 250 Lincoln is a nice all around machine. It is remote ready too. I'm fond of my bobcat, it's not fancy but it works. I like the 305 Lincolns, they have a good arc.
/ Engine Drive Welders #14
Check out alternator welders, you can build one pretty cheap and you might already have the parts around. Here's an old article to get you thinking. There's lots of better info out there now. You can build a 200 amp DC welder with a 100% duty cycle for pretty cheap - if you like to build that sort of stuff.
Build a Portable DC Arc Welder for $20 - Do It Yourself - MOTHER EARTH NEWS
Hope it's interesting!
Matt
/ Engine Drive Welders #15
Years ago I picked up a 400 amp Miller welding/generator with a Deutsch diesel engine mounted on a trailer. It has 6000 hours on it but it runs well and always start on first try
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
207283 (A52708)
207283 (A52708)
2011 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Insulated Bucket Truck (A60352)
2011 Ford F-750...
2014 Dodge Grand Caravan Van (A61569)
2014 Dodge Grand...
CK350KW SKIDDED GENERATOR (A60736)
CK350KW SKIDDED...
2013 FORD F250 (A60460)
2013 FORD F250...
