hawkone115
Greetings folks,
Hope I posted my issue in the correct forum. I own a 4x4 Ford 1710 tractor. UL06201 Unit #4J13B. I have never has any issues with any part of the tractor (except water pump) until now. The tractor has 1100 hrs. on it. For the first time last week I could not get the three point to raise. I notice I was low on hydraulic fluid so I put in about 1 gallon. I changed all hydraulic fluid today including front axle. No luck as the rear three point will not raise. I can raise it by hand lifting and it moves rather freely. The front loader works great with no problems.
I bought a county line brush hog from tractor supply about two years ago. I did noticed that when I raise the brush hog if I had it raised high the hydraulic hoses to the front loader would tend to pulsate, my usual reaction was to just lower three point a little until the hoses stopped pulsating.
Since I started with the fluid change I am now seeking advice for the next step.
The fluid had not been changed in a few years, and was a little discolored but not bad. The hydraulic filter was also changed (NAPA 1736).
Thanks
Ted
Thanks
Ted
