Diehard batteries
/ Diehard batteries #1
Rohdog
Clyde, Ohio
1978 D6806 Deutz,1966 MF 135
Diehard batteries ...I've had 2 now in less than 5 years...1 made it 2 years..the other 2 1/2 years....just get interstate and be done with it...what do u think? Oh ..by the way..they were both 5 year batteries 125.00...never again..they replaced the first one but not the second one.Interstate for me...from now on.
/ Diehard batteries #2
I wonder who is making Diehard Batteries now. Johnson Control was but I am sure someone said Sears had moved the contract. Then again I have heard there are only a few Battery manufactures left and they are making the majority of batteries sold under the various names in the US.
/ Diehard batteries
Yeah the guy that wouldn't replace the second battery that died on me said..they now have a new supplier..I thought they should replace the second one because they were 3-year free replacement...since he said no..for that reason I went with interstate.
/ Diehard batteries #4
Never had a Diehard. But the guy at Napa told me that the Napa Legend is the only battery (including Interstate I assume) that is made in the USA. Of course he's a salesman so perhaps he has a number of great lines like that. Anyway, I bought 2 of them this fall. One to replace another 75 month Legend that went 7 years and the other to replace something else. Both of those in cars, maybe not as good in tractors?
/ Diehard batteries
One reason I bought the interstate is...about 10 years ago when I worked for a road striping company here in ohio..we had arrow boards(each had 15- 4
" light bulbs in them) on all our trucks..one driver forgot to shut the arrow board off when he left the truck at the shop...when I went to work the next morning (it was dark) I saw the arrow board facing down to the cab..was flashing..so I pulled up to the front of the truck to give it a jump...but just for the heck of it I tried to start in before(thinking in my mind..there is no way it's gonna start..after 8 hrs on all night) and it turned over and started...Now that's a good battery.
/ Diehard batteries #6
I put a DieHard in my old SAAB 99. It died after a few years, so I took it back to Sears. They gave me a brand new DieHard. It never took a charge. This led me to spend a really unpleasant January day, out on the street, in the South End of Bridgeport, testing ground connections, fuses, fusible links, alternator, and voltage regulator before concluding the battery was junk. Got a refund (partial - and had to raise a ruckus for it) and put that money toward an Interstate that was still going strong when I sold the car, 5 or 6 years later. So I am biased. Don't listen to me.
/ Diehard batteries #7
one 3 battery manufacturers left in North America .....
/ Diehard batteries
There is no doubt..Interstate is far better than diehard...They use to be great batteries 10- 20 years ago..only reason I bought it was..i was at sears buying a socket set,at the time... I still (at that time) believed them to be good..I'm just gonna stick with interstate in everything...except my Harley.It's a shame to see these once great companys going to _ _ it.. I wont go back.
/ Diehard batteries #9
Sears uses different manufacturers for their batteries, some are better than others. I have had very good luck with the Die Hard Platinum batteries which are made by Odyssey with the gray case. I don't buy the other batteries Sears sells as they are no better than a Walmart battery which costs a lot less.
/ Diehard batteries #10
I have tried a lot of brands including the Optima and find that the brand Walmart sells (Duralast) is a good as any other and the warranty is usually a no questions asked if the battery goes bad.
/ Diehard batteries #12
Diehards are not what they used to be that is for sure. 3 years ago I put Interstate batteries in 2 of our vehicles, 1 of the batteries lasted 1 year, the other lasted 2 years. The replacement Interstate battery in the second vehicle didn't last 1 year, it had a dead cell. Interstate replaced it, again. I am not sure what my next battery is going to be... but I suspect it won't be an Interstate.,
/ Diehard batteries #13
I've been using the Rural King batteries, made by Exide. TSC has Exide with their label too, but RK is quite a bit lower priced. RK also runs storewide sales like clockwork so I keep a shopping list and grab all the big items when they run the sales. Their Ag batteries are built for rough use and have done well in my tractors. I've done the DieHard and the Interstate thing over the years, and gone the other extreme with Walmart junk for the small batteries. These RK batteries seem to do better than the Interstate for me. I use them in everything now.
/ Diehard batteries #14
Believe it or not, I've had real good luck with the gold looking batteries (can't think of the name right off hand) from Autozone. I also use Napa batteries and have had good luck also. No complaints from either brand.
Currently have an Autozone battery in the Chevy and a Napa battery in the tractor. Both are sealed and maintenance free. They are both pretty old. The one in my truck is just about ready for a new one. Done ran it down 2 or 3 times and it's getting weak now. This winter has took its tole on it. The one in the tractor has been ran down 2 or 3 times also. It's still strong as ever.
The battery on my zero turn mower is almost 5 years old with a little over 125 hours and has never been replaced or ran down. But I'm not sure what the brand is. Got me curious now...
For some reason, I've gotten better service life with maintenance free sealed batteries than I have with ones you have to add water or acid to.
/ Diehard batteries #15
One thing is should we be using Deep Cycle batt instead of automotive starting batteries? Given that our tractors sit for a long time between running, conventional batteries' voltage is dropping below 11 volts and lead plate sulphatization is occurring - just a guess. Using battery tenders or trickle chargers eliminate this issue.
I've been using Costco Kirkland batteries as of late and they're made by Interstate. Once the tractor battery goes, I'll have to go about finding a proper replacement.
/ Diehard batteries #16
I've been using Exide Batteries for a while too. Get them from Mill's Fleet Farm, have performed very well for me. They claim they are made in USA.
/ Diehard batteries #17
There are no batteries that one adds acid to except for wet batteries that have not yet had acid installed when they're new, before first use. After that water is the only thing that is to be added, distilled is best.
Interstate is what I use in everything I own. Used to sell them from my foreign car shop too. They're often only as good as the charging system that supports them, and this is across all brands. Some batteries of any brand can be duds too. Allowing any battery to drain below 80% of full charge will shorten the batteries life too.
Dats the facts jack!
/ Diehard batteries #18
One used to find tractor batteries that were dry and at time of sale the electrolyte was added. Anyone seen any of those lately. IIRC they did have to be charged to full capacity prior to use. I guess that is why they are all wet now as everyone wants them right now.
I had a Diehard battery die in my lawnmower after one year of use. Sears replaced it for free and the replacement is still in it after 2 winters. Many of the small lawnmower batteries die after one year of life. I do keep a trickle charger on it during the off months.
/ Diehard batteries #19
You can get atv/motorcycle batteries like that, but that's all I know of.
/ Diehard batteries #20
I too, was once a dyed in the wool Diehard battery guy. They'd spin the motor over like nothing else. But - they'd never last more than a couple of years. Sear's replacement warranty made that a non-issue. No more though.
So - I've changed to Interstate on everything I own, other than my Harley. Seems most other brands of batteries for Harley's are slightly off in size, post position, or whatever. And, although pretty expensive for a tiny battery, they do last very well. Over 7 years on my last one.
I did have good luck with AutoZone's DuraLast Gold batteries, however there are no AutoZone's nearby, thus the switch to Interstate.
Remember the old J. C. Penny's batteries with a LIFETIME warranty? After replacing mine 4 times - they shut that deal down :)
I sure can't believe how the price of batteries has jumped in the last two years though. I was told that it's a shortage of lead. Haha - not likely!!
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
