2130 losing hydraulic fluid
/ 2130 losing hydraulic fluid #21
IIRC the "negative stop screw"(parts key #23) isn't designed to be adjusted tight against L/D linkage but is intended to stop L/D linkage from moving too far in the wrong direction. As long as L/D lever under the seat is placed in "D" the L/D shaft can normally be fully removed without any ill consequences.
I made the mistake of trying to remove the shaft completely out one side and couldn't so put the seals in got on tractor and arms wouldn't do anything
/ 2130 losing hydraulic fluid #22
Did you have L/D control lever under seat in "D" before attempting to remove shaft?? I'll bet you didn't!!!!!!!! Many seals and shafts have been CORRECTLY replaced without the need to R&R rockshaft housing.
/ 2130 losing hydraulic fluid #23
probably not im a do it your selfer didn't know any better but I do now .being that everything you do these days cost money id rather do it myself and know its done properly are ask friends that have knowledge on the fix
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Ford Golden Jubilee (Model NAA) Tractor (A66285)
Ford Golden...
2016 Polaris RZR 1000 (A66408)
2016 Polaris RZR...
(5) Round Straw Bales (A66408)
(5) Round Straw...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
