Tractor backhoe - homemade
/ Tractor backhoe - homemade #521
I was just going to type what rScotty sent above...he beat me to it!:D
(just kidding of course - who knew there was so much involved in picking magnets.)
I used those magnets because they were lying around...so I figured they can only help. Filter and the magnets have an easy acess, so I intend to clean them up frequently.
Stabilizers and block valves are mounted. I poured the oil and did a first test...and.... IT'S ALIVE :)
Rotation works real smoothly, stabilizers also, other then a few tightings on the hoses I detected no problems so far. :)
/ Tractor backhoe - homemade #523
Then where are the videos !!! We're waiting with foam on our mouths !! :D :D
Patience is a virtue :) . Nothing before saturday
/ Tractor backhoe - homemade #525
Yeah, it is the patience factor that made it possible for this to be built in the first place.
/ Tractor backhoe - homemade #527
I ran out of patience and virtue when I was a little boy. :)
I'm happy for you (and your significant other) that you are near the end of a monumental task. I'm trying to guess what size that would compare to on an American backhoe. Maybe a Deere 310 or bigger? It sure looks heavy duty. Do you know the weight?
weight = around 1100 kg or 2425 lbs.
boom reach = 18 ft
stabilizer pads at ground level = 11 ft
/ Tractor backhoe - homemade #529
It is simply astounding that you built this.
/ Tractor backhoe - homemade #530
weight = around 1100 kg or 2425 lbs. boom reach = 18 ft stabilizer pads at ground level = 11 ft
Bfreaky;
Will the stabilizers have enough power to lift the tractor off the ground?
Looks awesome!
Sent from my iPhone 5s 64Gb using TractorByNet
Those are 15 ton cylinders, they can lift the tractor with no problem
/ Tractor backhoe - homemade #533
Wow. Looks great. Been following all along and I'm amazed.
(2) DOUBLE AXLE FENDERS (A64280)
(2) DOUBLE AXLE...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
JOHN DEERE 9360R ARTICULATING TRACTOR (A64280)
JOHN DEERE 9360R...
Grain Auger (A64119)
Kubota GR2020G (A63688)
Kubota GR2020G...
