david brown 990
/ david brown 990 #1
burcham
counce,tn
990 david brown
i have a david brown 990 and need a sterring shaft mine is 23 1/2 inch long and all i can find is a 24 1/2 anyone help. can the 24 be made to work or where can i get the 23 1/2
thanks
/ david brown 990 #2
Hoping this link carries through to the page. The part number you may be looking for is K906765. This would be part number 11C in the parts list column. Do be setting down... This is through Case/IH.
Case Parts Diagrams
/ david brown 990 #3
GRRR..., almost got far enough. When the page opens, click on "steering & front axle" at the bottom of the menu. Then select (HO2) in the menu. Let the page load, then scroll down until you find 11C in the parts list.
Is this it..??
/ david brown 990 #4
thanks
I need a steering shaft, ball nut assembly, ball tube and recirculating balls for my David Brown 990. Were you ever able to find the one you needed? If so where, please. If not, did you try to have one made? My e-mail is genie15@hughes.net. Thanks for answering. pcunfriendly
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
2010 Deere 318D (A60462)
2010 Deere 318D...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
