david brown 990
/ david brown 990 #1
burcham
counce,tn
990 david brown
i have a david brown 990 and need a sterring shaft mine is 23 1/2 inch long and all i can find is a 24 1/2 anyone help. can the 24 be made to work or where can i get the 23 1/2
thanks
/ david brown 990 #2
Hoping this link carries through to the page. The part number you may be looking for is K906765. This would be part number 11C in the parts list column. Do be setting down... This is through Case/IH.
Case Parts Diagrams
/ david brown 990 #3
GRRR..., almost got far enough. When the page opens, click on "steering & front axle" at the bottom of the menu. Then select (HO2) in the menu. Let the page load, then scroll down until you find 11C in the parts list.
Is this it..??
/ david brown 990 #4
thanks
I need a steering shaft, ball nut assembly, ball tube and recirculating balls for my David Brown 990. Were you ever able to find the one you needed? If so where, please. If not, did you try to have one made? My e-mail is genie15@hughes.net. Thanks for answering. pcunfriendly
1993 Brenner 307 SS Insulated T/A Chemical Tanker Trailer (A68183)
1993 Brenner 307...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
CAT J600 Teeth (2) (A68134)
CAT J600 Teeth (2)...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2017 HINO 195 4X2 S/A  16FT BOX TRUCK (A69167)
2017 HINO 195 4X2...
