Big Difference on M7060
/ Big Difference on M7060 #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
I finally got around to widening the tires from 74" to 86" and filled the rear tires with water and one gallon of anti freeze to each. The stability is noticeably better. It's quite the project to move these big tires and wheels.
/ Big Difference on M7060 #2
What's your reasoning for only one gal of antifreeze per tire? Do you know the freeze point of the mixture? Thanks,Jim
We are in S La and freezing temps are rare so one gallon per tire will get me plenty below the freeze temp and also prevent corrosion to the steel wheels
/ Big Difference on M7060 #4
How did you determine that a gallon of antifreeze will keep water from freezing when mixed with 73 gallons of water?
/ Big Difference on M7060 #5
Not certain the 1 gallon is going much for freeze protection. Here's a chart for the OP to reference to see if he feels comfortable with his ratio.
/ Big Difference on M7060 #6
Granted AF solution can get slushie without harm to tire but will 1 gallon of AF accomplish this in 70+ gallons of water at say 15 degrees F?
/ Big Difference on M7060 #7
The OP said he lived in South Louisiana, so rarely will it get below 40F in winter. In the rare instance of below freezing weather, it would only last a day or so and then warm back up. I would say the average temps there is above 50F most of the winter. I grew up in North Louisiana and we used pure water for ballast. The occasional freeze would only last a day or 2 and if the tires got frozen a bit, we just let the sun thaw it out. NO snow to move and usually nothing pressing to do when it was below freezing so we just wait till it is nice outside to do any winter work.
/ Big Difference on M7060 #8
I knew PO lived in S Cajun country but then why put one gallon of AF in the tires?? Back when I used my JD 4255 for plowing I put straight H2O in the tires BUT if below freezing my tractor stayed parked in barn and I didn't move it. Normally it doesn't snow in the Southern states BUT it has this year. If a tire freezes it takes a while for it to completely thaw. Maybe Oiltech will have no snow to move but he might have animals to feed.
Neither work or animals, mainly it was to treat the water, freezing is not a concern
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2008 Chevrolet C4500 Truck, VIN # 1GBE4V1998F404142 (A61165)
2008 Chevrolet...
2015 Ford F-350 Crew Cab Pickup Truck (A61568)
2015 Ford F-350...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
(2) UNUSED 25X8.50-14 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED...
Vision 250/50R15 77D Golf Cart Tires (A61166)
Vision 250/50R15...
