Reviews on this Machine
/ Reviews on this Machine #2
I think Eastwood generally has a pretty decent product and for an AC/DC TIG, that machine is about half the cost of a Miller Diversion 180 that is strictly a TIG machine. It might be worthwhile to compare it to a similar Everlast or Longevity machine.
/ Reviews on this Machine #3
It's a Mosfet unit and they don't repair the units. If it fails after 3 years, you are out of luck. And if it breaks, they'll exchange it for another one.
Sorry, I'm afraid I don't know what a Mosfet unit is. If I buy 1,,it will be for home use only No fab shop work just small personal projects. Is there a better machine close to this price range.. They have this 1 listed on E bay for $899.00 including shipping. I haven't committed to buying anything, Just kicking tires right now
/ Reviews on this Machine #5
Some info on them:
http://www.crown.co.za//resources/docs/African-Fusion/Sep-2009/Inverters.pdf said:
We ask about reliability: "Early inverters used thyristors, which can be turned on in the forward half cycle but can only be turned off by reverse biasing the device. This can only be achieved by using a naturally resonant circuit, which is more difficult to control and you can only make changes during the positive half cycle.
Then came the use of MOSFETs (metal oxide semiconductor field effect transistors). These can be switched on and off so they don't rely on a resonant circuit but they are not very robust. Any voltage or current spike will destroy a MOSFET," he tells African Fusion.
IGBTs, he says, have now led to a new generation of much more reliable inverters. "Every year, manufacturers come out with newer and better IGBTs – more reliable, faster switching and with lower losses. The switching devices in the early inverters were the weakest link.
With IGBT, that is no longer the case. We have machines that have been running for 10 years or more. There are about 24 000 Reeflex inverters currently being used mainly in southern Africa, and they have proved to be very robust. You can't break our machines unless you abuse them," he claims.
Aaron Z
Can anyone tell me if this LONGEVITY Tigweld 200sx - 200 Amp AC DC Tig/Stick Welder with Digital Display 110v 200v - Amazon.com tig machine has the same internals as the 1 from east wood ? If IGBT's are the best. That's what I'll look for. Do the specs. for a tig usually tell if it is IGBT or MOSFET ?... I'm not looking to spend mega bucks. I just need a machine that will weld aluminum . I have a flat bottom boat that is always getting holes knocked in it. I need a TIG that has voltage low enough to be able to weld up this thin alum. boat + be able to weld a little thicker alum. (1/8'' - 1/4'') would be great. I'll keep kicking tires until I find something
/ Reviews on this Machine #8
MOSFETS, The same crap they use to do the hi current switching in most inverters! They like to Go Snap, Crackle and Pop! They literally do! And they don't quit til theyr'e all blown.
/ Reviews on this Machine #9
IIRC, the older Longegity machines were MOSFET machines, the newer ones appear to be switching to IGBT. Looking at TIG Welders GTAW, TIG Welding Equipment, TIG Welder For Sale (the "Models" tab) the 200sx is listed as "Inverter" vs "IGBT", so I would guess that it is a MOSFET machine.
With both Longevity and Everlast, if you email or PM them, they often have a "TBN Price" that is at least as good as the Amazon price and for a fresher/newer model machine.
Aaron Z
/ Reviews on this Machine #10
Longevity can. Like anything, Google the manufacturer and model, click on their site and there you go. Your answer is at the very bottom of the grey gradient box.
Note since you linked it from Amazon, the Amazon reviews for Longevity machines are fake reviews from Longevity.
I wouldn't exclude an Eastwood MOSFET machine from your search, great price point especially the 200TIG and 60a plasma combo with cart.
MOSFETs are not crap at all, it's more of a marketing ploy by the cheap Chinese-built weld/plasma machine sellers because the first few generations of machines (and some still sold & produced) blew em up all the time, and since the MOSFETS carry all the amperage, they go up in smoke. IGBTs are newer in the application and better suited for most of the work, however MOSFETs that blow up in these machines were from absolute garbage quality control, poor cooling, improper design and using cheap, improperly specced MOSFETs. You don't find older Lincoln/Miller/etc MOSFET machines blowing up right out of the box and left and right in use.
All these units to my knowledge are made by contract in Chinese factories. Longevity, Everlast, Giant, Eastwood, etc. do not design the electronics that comprise the machines. They can request changes and different specced parts to respond to common problems, and stock and provide parts for the machines. As you've seen Internet forums/sites are a huge sales channel for them. Many of the machines are nearly identical in design to others, and many are made in the same factories by the same companies.
Consider all this in your decision. The Eastwood MOSFET is not a IGBT, but it has good legitimate reviews for the machine with some issues with the company and machine. Eastwood has been around for a long time and there's a good chance it will continue to be. I haven't heard any complaints about fake reviews or ripping off images/content from competitor sites or things of that nature about them though.
I am not recommending one machine over another, I wouldn't exclude any of them from the running... There are just lots more parameters to think about. As much as they are not IGBT machines, they pale in comparison regarding quality/parts availability/service/etc. to Miller/Lincoln/etc... So it depends what the best value for you is.
Gee, I just wanted to buy a descent Tig machine (with out spending tons of $$) to weld aluminum. Now, I have to decide it I want MOSFET or IGBT machine. Now I know how my customers feel... Do I want a 13 seer A/C or a 16 seer A/C with 2 stage compressor, dual speed motor,etc,etc, ??:laughing:
/ Reviews on this Machine #13
You know you can Tig weld with any DC buzz box, a Tig rig, and a bottle of argon? You can even do aluminum.
DCEN with 100% helium. Pretty much cut your amps in half from AC with 100% argon. Only problem is you have to make short welds, no way to control the heat, as the heat builds up in the material.
Here is some I did on DC with a Tig rig, and a Stainless steel Tig weld I did with my Everlast PowerArc-200.
/ Reviews on this Machine #14
Ishaboo...
Oh, where do I start. So many inaccurate and misleading statements...not enough time. You are very ill informed. From the statement about our control in the factories to the statement about mosfets. I will address the MOSFET issue from an easy to understand view: Most all welding manufacturers have left MOSFET designs for a very good reason. The only one left that I am aware of in the major players is ESAB and I think they've pretty much converted over. Their old plasma cutters were well known for a good bang or two because they were MOSFET based.
Miller doesn't design the electronics either...they have them made in China and imported here, with rebadged names reflecting their chips. I've got several links to Miller's factories in China. I won't air their dirty laundry here, but what you are saying is based largely upon lack of knowledge and heresay. We use name brand components, most from American based companies in our products. No we don't design the IGBT's. No we don't design the rectifiers etc. We use off the shelf components that are readily available, and don't attempt to make an electronic item an OEM only part. But we have a lot more control over some things than you think.
You DO find older Mosfet units from Miller and Lincoln blowing up. That's why you don't see that many around if they had very many.
You apparently missed the post that linked to a strong South African manufacturer of inverter welders...These guys don't play. They have 100% duty cycles in their inverters. I've known about them for some time. This isn't a Chinese thing. It's an industry thing.
/ Reviews on this Machine #15
To the OP, we have our PowerTIG 185 which is a good, well performing IGBT machine. The last I knew the Eastwood machines weren't putting out a full 200 amps on AC. But the 185 is pretty strong, and gives more AC adjustments than the 200 Eastwood. It doesn't have pulse though. I can make a special price to TBN members.
/ Reviews on this Machine #16
I know for a fact that the early Miller XMT 300's blew circuit boards or whatever on a regular basis. I know a shop that bought one. Fixed once on warranty and blew up again off warranty. It was almost the cost of a new machine($1000's) to fix it. Even Powcon, who pioneered inverter welders, claims they have went to the more reliable IGBT inverters. I mention Powcon because that's how Miller got into inverters. I heard they purchased Powcon but I looked awhile ago and Powcon still has their own machines. Don't know all the details but inverters have definitely improved. Early Lincoln inverters had a lot of problems too. Why not see what kind of deal Mark would give you?
Thanks for the info.... I'll give you a call when I decide to buy
/ Reviews on this Machine #18
You could probably buy a couple new aluminum boats for the cost of the welder. I would look for a tig setup for a buzz box or a spool gun for a mig setup. Or just quit running your boat so shallow.
/ Reviews on this Machine #19
Ishaboo...
I'd respectfully disagree. I appreciate the marketing and sales that is going on, but I am trying to present honest information to the OP and not sell anything. I own a nearly new Millermatic 252 I bought in December, have had a Hobart in the past, and I'm shopping for a TIG and Plasma which will likely be one of the off-brand units due to my infrequent use and costs. I have a background in electrical engineering so I'm VERY familiar with what is being discussed here.
Yes, IGBT is "newer" technology for the newer devices but just one component in a complex electrical device. It's more applicable to the newer high-frequency machines that MOSFETs performed less favorably on. I never said that buying a MOSFET machine was the newest, most advanced piece of technology possible. I'm arguing a quality machine with MOSFETs are a good value, and that the huge failure rates are associated with poor engineering and poor quality. The switch to IGBTs came because of better high-frequency, high-amperage operating characteristics.
Quite wrong. Miller most certainly does design their electronics. But I believe you're confusing "electronics" with "semiconductors". First, nearly ALL semiconductors ("chips" and discrete components, for example) are made in East Asia, and probably 95% are not specific to an application. Any time you buy anything "Made in USA" with any circuits, those circuits are made from Asian semiconductors… there's no feasible way around it.
Miller has a team of electrical engineers who create the schematics to make a device that produces a particular welding output, build their own PCBs from scratch from discrete components and perhaps a couple FPGAs/etc., and researches, tests and analyzes their performance. At the price point, they will spec the components used to be appropriate for the duty cycle and operating conditions as well as the operation of the device, whether it be a MOSFET, IGBT, resistor, capacitor, or anything else. This is the same as how motherboards for computers or nearly any board is made for any type of device, from your laptop to your television remote.
NO manufacturer of welding equipment let alone nearly anything else in the world makes their own semiconductors, and that's highly unlikely to change in the next 50 years as there is no reason.
When a circuit is complete, like almost any other product manufactured, the board layouts are sent out to a PCB manufacturer who creates the boards, solder masks/tins/conformal coats/etc., does the pick and place, tests the boards and ships them to Miller. I doubt there are few if any chips labeled Miller as you say, but perhaps there are a couple, the most likely being FPGAs or micro controllers which are essentially generic outside of the label.
As I said and will repeat again, to my knowledge Everlast, Longevity, Giant, etc. and for sure Eastwood do NOT design the circuits or schematics that make up the welder. I am not saying this is a bad thing, and as I've said before I am considering a TIG/Plasma from any including your own company. (Though like Longevity's fake reviews, the misleading marketing efforts are beginning to bother me. And why do you guys all copy from Miller like your navigation process images? :))
I see a ton of old Millers/Lincolns around.
But welding technology has come a long way, and most companies upgrade their machines to current models offering features like easier starting, better welding, etc… which is what those circuit boards, schematics and research accomplishes. The new inverter machines are lighter and weld better.
The older welders from these name brands were not known for randomly dying or anything in a frequency higher than any other complex electrical device under the conditions they operate in. There were problem units from a few, none of which I'm familiar with had an issue with the MOSFETs blowing up.
Not sure how that's relevant or how I indicated I missed it?
Let me clarify "Chinese thing" however. China is perfectly capable of producing nice, quality products, which I believe the recent generation of welders you guys sell are. They're just the ONLY country capable of producing these complex products at such a LOW price point, so they get a bad rap.
Just like "don't buy Chinese", "don't buy MOSFET" is a similarly dangerous statement that restricts you from some nice value machines.
/ Reviews on this Machine #20
Yeah, the 300s had a bad track record.
Did you know they are IGBT machines though? :) And the IGBTs were what went? :)
2011 CATERPILLAR CB434D DOUBLE DRUM ROLLER (A65056)
2011 CATERPILLAR...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
25210SFL (A64557)
25210SFL (A64557)
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2012 COMPTANK ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK ACID...
