pallet forks add on plate- for moving hay??
   / pallet forks add on plate- for moving hay?? #1
sd455dan
Super Member
North Idaho
Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
I'm sure someone else has done this -but thought I would add mine..
We buy hay every year for the horses and usually comes in a self stacking bale wagon of approx 4 ton.
Problem is neither of the two barns have doors or ceilings high enough for the wagon to enter and (set the load) so it always gets dumped outside- this year almost 100 yards from the barn (no one home) when delivered.
We needed to move and stack 16 ton so out comes the pallet fork plate- built it about 4 years ago hay 2013 006.jpg hay 2013 002.jpg hay 2013 004.jpg
It makes it easy to drive up to the pile of bales set the plate down, stack 9 to 12 bales, -lift the loader, drive in to the barn and then place the bales where needed.
The plate of hay can be lifted to even the 6th level of the stack, and makes it easy to build a vertical faced stack... also saves a Whole lot of extra back breaking work lifting bales to the upper part of the stack.. the plate can be used for moving about anything that will fit...
If only moving bales once in a while-
a well built pallet (secured) to the forks will also accomplish the same thing..
(saving your back)
Happy Hay stacking:thumbsup:
   / pallet forks add on plate- for moving hay?? #2
I am wanting to lift the hay pallets off my trailer that is behind my baler. Any suggestions on how to make the forks for the bucket or where to buy them. Got to get away from back breaking stacking.hay bales. Lol
   / pallet forks add on plate- for moving hay?? #3
I stack my hay on pallets.... Then just unload the pallets with pallet forks..... My back told me I had to do that.....
Bought mine from GC manufacturing. they are round so it is a little more challenging to get them ( In the Pallet) the price was right around $200 but they are rated for 3000 lbs. and have held up well... found these for $230 witha 2500# rating and a 25 year warranty Clamp on Bucket Loader Forks Skid Tractor Pallet Forks | eBay
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
