2014 Model J2023
/ 2014 Model J2023 #1
Olympus
Cape Girardeau, MO
LS R3039
So in my search for a new tractor I recently found LS. I like the 2023 size because it is bigger and beefier than other SCUTs. I went and priced one at a local dealer today and spent a little time driving it. First question is if the price they quoted me is realistic or fair. Dealer said $12,900 for the 2023 with a loader.
Next question, I noticed that the tractor had a pretty bad shake in the hood area at idle, especially right after it first started. Is this normal? Could this just have been because the weather was so cold? 18 degrees today.
/ 2014 Model J2023 #2
Sounds like it needed to warm up a bit, should have smoothed out in about 10 to 15 minutes, but 18 is cold on a diesel that hasn't been plugged in with the block heater, but it's nice to know that they will start when it's that cold. I would check a couple of other dealers on price just to see where the dealer is in relation to their quotes.
/ 2014 Model J2023
That's what I was thinking too. Cold weather like that is hard on a tractor that's been sitting outside.
I was really impressed with the tractor. It's noticeably bigger and beefier than the SCUTs I've been looking at, JDs, Kubotas, and Kiotis. Bigger frame, more ground clearance, bigger tires, and standard Class 1 3PH. I just need to sell my little JD 750 and get some money to buy with.
/ 2014 Model J2023 #4
We get a lot of wild temperature changes in Denver, if I know that it is going to snow, I plug the engine block heater in after the late news, sure makes starting a lot easier and less strain on the tractor and starter motor, I also use a battery maintainer 24/7, one of the $20 units from Walmart works great and hardly uses any electricity.
/ 2014 Model J2023 #5
I was quoted 12,500 from a dealer near Tulsa and he was pretty firm on that. So I would say he is in the ball park might get him down a few hundred.I would say it is equal or outperforms other SCUTS on the market and at a lot better price. In case you didn't know this is the same tractor as new Holland only with a heavier loader.
/ 2014 Model J2023
I've called ever LS dealer within about 2.5 hours of me and Magee Equipment in Poplar Bluff, MO has easily had the cheapest quote. I'm not affiliated with the dealer in any way, just wanted to share if there were others in the Midwest looking for an LS. Magee told me that a new J2023 would be $12,200. I've had other dealers quote from $12,500 up to $13,200.
If I can sell my little JD 750, I'll be going to Magee almost certainly.
/ 2014 Model J2023 #7
I don't have a 2023, but I notice both my LS and Massey definitely have some extra shake and bake when they first start up in these cold temps we're having. I set the idle around 1000rpm and do other stuff for a few minutes, and they're purring along just fine. What you're seeing is the cylinders not getting complete combustion (hence the smoke) and that means it's not equal from cylinder to cylinder, so you're getting unbalanced impulses.
/ 2014 Model J2023 #8
Bought mine at Magee's. Beat the local by 3k. Talk to Doug. He will shoot you a straight price from the get go. No haggling, just a good deal.
/ 2014 Model J2023 #9
I just bought a 2013 J2020 this week. It was new. The only difference it has with 2023 is the loader. Its the same tractor. It was $11,800 here in NC. I love mine. Its the perfect size for what I needed. The JD, Kubota, and Massey of the same horsepower were a lower to the ground plus more expensive.
Sam
/ 2014 Model J2023 #10
Sam
Welcome to the new Blue!
/ 2014 Model J2023
Sam
I think the differences are the 2023 has more loader capacity, 9.2gpm hyrdo pumo instead of 8.6, and the dual pedal setup.
Sounds like you got a great deal!
/ 2014 Model J2023 #13
You're exactly right about the differences. I think I got a fair deal too. When you compare the LS to everything else they are the best bang for the buck.
I think you will like the little tractor.
/ 2014 Model J2023 #14
Your exactly right. The larger hydro pumps increases lift by about 200 lbs. LS did this because they are discontinuing the j2030 because of the new tier 4 engine regulations. I just purchased a J2023 myself for $ 12,000. Suppose to pick it up next week. I can't wait.
/ 2014 Model J2023 #16
Howdy antlers 125...
I just joined this forum because I saw your note from last night. I'm about to pull the trigger myself on one of these J2023s -- but you got a much better deal that the numbers I'm being offered. Would you be kind enough to let me know what dealer gave you such a sharp price?
I'll call them up and make the deal with them, if they're not too far away.
Thanks so much for your help...
Jimbogo
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
S/A CATTLE FEDDER (A63291)
S/A CATTLE FEDDER...
2018 Ford F-150 4x4 Pickup Truck (A61573)
2018 Ford F-150...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
