Loading rear tractor tires
/ Loading rear tractor tires #1
Rohdog
Clyde, Ohio
1978 D6806 Deutz,1966 MF 135
Can you load tractor tires yourself?..Just wondered what % to put in and how.
/ Loading rear tractor tires #2
Yes, you can. Fill to the top of the rim. so about 75%. The fill/burp valve is readily available for about $10. (at tractor supply, Gemplers, mail order) You will need a pump unless you use just water, I used the cheap junky drill pump from Home Depot. There are dozens of threads on how to do this.. lemme know if you can't figure it out, and I will type it all out again.
Ok..i'll give it a try..gonna put tires on rear...in a few weeks...Thank you
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2003 International 4300 Bucket Truck (A62613)
2003 International...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
Yale Forklift - NO RESERVE! (A63688)
Yale Forklift - NO...
