Extreme cold causing house to settle?
   / Extreme cold causing house to settle? #11
Quick background. Original house w/basement built in early 60s. Added a second story in mid-90s. We have had weeks of cold weather, much below normal and nothing like this since the remodeling. Recently we have heard thuds that sounds like a large branch hitting the roof. I rushed outside after the first one, but nothing on the roof. It is a brick on the bottom wood siding on the second story house and I don't see any cracks in the bricks. It was 6 degrees out this morning when I heard another thud about 5AM.
The other "clue" is a bathroom door isn't closing properly. Had to shim the bottom hinge. What should I be looking for to find the cause of the thuds? Should I call someone to do an inspection? Or not be too concerned?
Thanks!
I have 2 decks on my house, and they "pop" quite often especially when it gets down near zero. I would think that is what you hear.
   / Extreme cold causing house to settle? #12
Likely just a deeper frost line than in the past decade or so. So the ground is heaving in different locations than in the past, this could be due to a change in water run off, deep than usual ground water over the summer and so on, as others have pointed out, low humidity is also a factor, and can be noticed in furniture, cubbard doors, wooden chair joints being loose. To ad humidity, place a tea kettle on the stove, or better yet wood stove and let it simmer all winter topping off as needed..
   / Extreme cold causing house to settle? #13
that is what i have when you have below zero temps.my deck is 12x 32 and she makes a real loud snaps at times.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2006 International 4400 LP Ambulance (A50323)
2006 International...
