Kubota BX2230 or Branson 2400H?
   / Kubota BX2230 or Branson 2400H? #1
buckslayer5676
Kubota
Hi all,
I'm looking to purchase my first tractor and need some input on what everyone thinks would be the better choice.
The first one is a 2005 Kubota BX2230 (bought new in 2006) with 265 hours that comes with FEL and 60" MMM. Original owner is selling it and it has been meticulously maintained. Owner is very mechanically inclined, so I'm confident the machine has been taken care of. Includes a few small extras. I can get it for around $9100.
The other one is a 2013 Branson 2400H with only 25 hours with FEL and Land Pride back blade. Only 3 months old and has only been used for plowing snow. The factory cover is still on the rear PTO and it's never been used. The full Branson warranty is transferable to the new owner. I can get it for $10,000, which I think it a steal. I priced a new one and it's around $13,000 w/out taxes.
We're going to be building a house this spring, so I suspect I'll get a lot of use out of the tractor for landscaping, moving fill, etc. I also plan to use the tractor for mowing my lawn, snow removal, brush cutting trails in the woods (there are already existing logging trails, so not too heavy of cutting), and tilling up about a 1 acre food plot for hunting.
I realize if I got the Branson, I'd have to pick up a rear finish mower for the lawn and I'm guessing the Kubota with the 60" MMM may be a little more ideal to use as a primary lawn mower (let me know if you think otherwise). If I bought the Kubota, I'd have to either get a back blade or rear snowblower.
The Branson is little bigger and seems to have much better ground clearance (8" vs 13" I believe). The only thing I'm worried about on the Branson is the reliability vs. the Kubota. The warranty would obviously help short term, but I'm thinking long term down the road.
So what does everyone think...get the Kubota for $9100 or Branson for $10,000? Which would be the better deal?
Anyone?
   / Kubota BX2230 or Branson 2400H? #3
The BX is a wee bit over priced unless there are quite a few goodies thrown in, as you mentioned. Not grossly over-priced, but certainly no bargain. The Branson is a bargain, in my view, especially since it is warranty backed. I'm not familiar with that model, but I've many, many hours on a larger Branson and it is a limited frills, but solid, heavy, hard working Korean tractor. Very tough machine. It has fairly powerful hydraulics that would far outwork a BX, I suspect.
You mentioned working in the woods. The BX is not nearly as suited for working back there. It is awesome for yard work, light material handling, mowing, and so forth. These two machines really do not compare well as to the target buyer intended. That Branson compares much closer to a B2620 or similar. The Branson has virtually twice the real world ground clearance of the BX. In the end, the decision is yours of course, as it is your money and yours to own and operate. Wish you the best.
Thanks BP. I think I'm going to go with the Branson.
   / Kubota BX2230 or Branson 2400H? #5
Hey buckslayer,
I agree with the branson choice, but would want to make sure you have a servicing dealer somewhat close, warrantee is great only if someone is going to honor it. I have both a branson 6530 and a kubota bx 25d so I do not have a dog in the "brand" hunt but would put more faith in the serviceability going forward.
Good luck
Dave
Hey buckslayer,
Good luck
Dave
Good point Dave on the dealer. Luckily I have a servicing dealer very close by (where this tractor was actually originally purchased).
   / Kubota BX2230 or Branson 2400H? #7
If that is the case , sounds like a no brainer. 25 hours is nothing and I have had no problems in my 400+ with my branson.? Good luck in your purchasing decision
Dave
Dave
Thanks Dave!
   / Kubota BX2230 or Branson 2400H? #9
Well Sir,
Did you buy this Branson and if so, do you like it?
Yes, I actually did end up buying the Branson 2400H. Ironically, I just sold it as my needs for a compact tractor have changed.
I really loved the Branson and I would buy another one if I was ever in the market for one again. I did have some issues with the front boom seals leaking, but the local dealer took care of it (under warranty of course since it was a 2013 with only 35 hours).
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
WATER TRAILER (A58214)
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
43055 (A55851)
43055 (A55851)
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
