All copper ground clamp
/ All copper ground clamp #1
ericher69
Ontario Canada
2008 Kubota b2920
Anyone have a good place to buy an ALL copper 300A ground clamp? Checked eBay, Amazon some LWS and cannot find one. Plenty of brass or partial copper cast clamps Trying to replace the stock clamp on 252.
Thanks
Eric
Sent from my iPhone 5s 64Gb using TractorByNet
/ All copper ground clamp #2
I know it isn't what you are looking for but I just replaced my ground clamp on a new 252 with the typical curved brass one and it made a big difference.
/ All copper ground clamp #3
Lenco. Model 300 or model 500 (500 is a bit of overkill, but it will work)
Available at Air LIquide and other LWS. Sold under the Blueshield brand and Lenco.
Great clamp. Solid bronze. Made in USA. I HATE the factory stampped metal clamps, added a Lenco to my 252 soon after getting it. The stock clamp is OK because it has a nice bronze pad, but the Lenco is much better. Improves performance too. About $50, for the 500A at AL.
yhst-49369779241392_2269_301589314
/ All copper ground clamp #4
Regardless of whether you keep the cheesy clamp or get a lenco or tweco one, find one of these
Braided ground battery cables
cut a piece of it about 3" long, fasten it to the side of your clamp that's connected to the actual work lead. This is just a slightly more elegant version of one of Jody's tricks (weldingtipsandtricks.com) ... Steve
/ All copper ground clamp #5
They don't make em, they're all bronze or brass
/ All copper ground clamp #6
Why copper? I use the brass Tweco's with no issues with the clamp anyways.
/ All copper ground clamp #7
Link to the referenced pages: Welding Ground clamp for Odd Shapes and Round Parts and A Better Mig Welding Ground Clamp
Aaron Z
/ All copper ground clamp #8
The OP is probably mistaking bronze or brass clamps as cooper, and then when he reads the description that they are bronze, he thinks they are inferior. There would be no reason to even build a copper clamp, they are too soft and weak to hold up to the abuse.
/ All copper ground clamp #9
Brass is a combination of copper & zinc. Bronze is a combination of copper & tin. Both alloys are made up of various percentages of each metal but I think most bronzes are made from about 85% or higher copper content.
/ All copper ground clamp #10
What is the point anyway? I have gotten into the habbit of clamping on any large pair of vice grips (not C clamps) that are handy when Mig Welding. Then I take my large brass ground clamp and kind of clamp it into the vice grips because I'm so **** tired of the brass clamp either not making contact because it's not sharp or coming off at the most inopertune moments! I'm kind of thinking of doing away with the brass clamp altogether and just attach my ground to a pair of vice grips.
Lincoln CV 250, 3 Phase 600 Volts, not sure of feeder model #, also Lincoln.
/ All copper ground clamp #12
What is the point anyway? I have gotten into the habbit of clamping on any large pair of vice grips that are handy when Mig Welding. Then I take my large brass ground clamp and kind of clamp it into the vice grips because I'm so **** tired of the brass clamp either not making contact because it's not sharp or coming off at the most inopertune moments! I'm kind of thinking of doing away with the brass clamp altogether and just attach my ground to a pair of vice grips.
I know someone who did that. He welded a bolt to the top of the "fixed" jaw of his vise grips and would attach his ground wire to that. Worked well for thin stuff (under 3/4").
Aaron Z
/ All copper ground clamp #13
There are some negative reviews on the Twecos complaining about the high spring rate so they might double as grip exercisers.
I have a couple small Tweco ground clamps, I think they are rated at 200-amps. They are for a jumper ground lead from my welding table to my tripod chain pipe vice. They are a challenge to open up!:shocked:
/ All copper ground clamp #14
My friends that do a lot of welding, like probably millions of welds, just use an old hook made out of say 5/8" wire rod, that they drape over whatever they are working on. Sometimes it just sparks, and they give it a nudge and everything is fine once it arcs itself on, I guess.
I have enough trouble trying to weld without need for poor grounds!
No I am not mistaken. There are pure copper clamps made!
The reason to use pure copper; best conductor of electricity only second to gold.
You don't want to offer any places to find these then don't bother replying...
/ All copper ground clamp #16
N I C E !
And B T W,,,You are WRONG!
SILVER FIRST (Although it does tarnish)
COPPER SECOND
GOLD THIRD!
point is that's what I want
N I C E ! And B T W,,,You are WRONG! SILVER FIRST (Although it does tarnish) COPPER SECOND GOLD THIRD!
WHY ARE YOU YELLING?? I stand corrected...Medal for you! Talk about taking something to heart. Glad your vise grip trick works for you. I don't have a million clamps yet so need them when I build something.
Last time I searched there where no ground clamps made of silver or gold...
/ All copper ground clamp #20
Thought I could be a miserable SOB!
My friends who have been welding since they were probably in diapers would likely have a good laugh at your copper ground clamp request. If you do all the figuring of the given circuits materials and resistances, I'm almost certain THAT (There I go yelling again!) would make as good as no difference what so ever.
Hope you find what you are looking for.
Have a nice day.
2015 Jeep Cherokee 4X4 SUV. (A66738)
2015 Jeep Cherokee...
2011 CHEVROLET IMPALA CAR (A66091)
2011 CHEVROLET...
2018 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2018 Toyota Tacoma...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
