Bucket Level Indicator
/ Bucket Level Indicator #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
Here's a really simple item that made life easy. I was recently moving lots of dirt to bury a 1,000 gallon propane tank. The lower part of our yard became the donor area because it is bottomless topsoil. There's a large area that I cut down from nothing at one end to maybe 18" at the other. The first pass was after running a disc over it to loosen it up. As the loosened dirt was used up I discovered the stainless wear / cutting edge I added to the bucket could shave virgin dirt, so I quit discing and went with it. The challenge was to get the bucket at just the right angle to peel a layer off without digging in and making holes.
All it took was a piece of 1/4" plain rod, an eye bolt, short piece of 1/2" Sch40 clear PVC and a joint used on HVAC dampers. The swivel was installed on the bucket bracket and the eye bolt opened enough to squeeze the PVC through it. It was then a matter of taking the tractor to a flat concrete spot and adjusting the PVC so the end of the rod was even with the end of the PVC when the cutting edge was level. It made a huge difference by being able to get the angle right. The first attempt used a simple bend in the rod similar to those that come on some tractors. It didn't allow for eyeballing nearly as fine an adjustment and was scrapped.
/ Bucket Level Indicator #2
thats good to me i hope its better then the factory junk
/ Bucket Level Indicator #3
I'm sorry, maybe its just me but I don't see anything that I can see is a bucket leveller in those pictures. I don't see anything at all in the first pic and the second one I see a silver tube coming up and back at 45 derees but I have no idea how that tells you that your bucket is level. What should I be seeing there? Even after reading your desscription I still have no iea how this works. Can you circle the bucket leverler parts or something? Thanks.
/ Bucket Level Indicator #4
Forget the 1 st photo, on the second one if that silver rod is level with the white tube his bucket is flat.
/ Bucket Level Indicator #5
After zooming in I see it now, my bad. I thought the silver rod in the first pic was part of his hydraulic lines and I couldn't see the rod inside the tube in the second pic, I thought it was just one big fat tube. Zooming helped though and I get it now. Thanks.
/ Bucket Level Indicator #6
That is the same principle that is on my LS loader except it uses a solid steel tube. Nice and heavy duty BUT you cant really tell how much the bucket it tilted down as just like yours when level it is flush and as you tilt it, the rod disappears inside the tube so it is just guess work at that point. At least I have a starting point though. My Kubota B26 has the little rod floating in a flat plate with a crook in it for level indication. It can be tilted quit a bit from level and still be in that crook so it isnt much value. Mostly just have to do it by feel similar to using the backhoe under water to dig.
/ Bucket Level Indicator #7
The one that came on my New Holland 820 TL is very similar but the movable rod is not completely hidden by the jacket pipe. There is a yellow target piece that slides up and down on the shaft to set the level by referencing it to one of the mounting clips. This is very practical because it is universal with different buckets and you can set it to another point if you just want to dig in a little.
As you said, doing it by feel becomes the norm anyway after a little practice, so it is just a gimmick for new tractor folks.
/ Bucket Level Indicator #8
Probably just a matter of time before one of the manufacturers comes up with a bucket level indicator readout on the dash. How about a GPS "you are here" so we don't get lost in the woods.:)
/ Bucket Level Indicator #9
A couple of options: 1 - Cut an angle on the top of the PVC tube. You adjust the top point even with rod top when level & then you can lower the bucket to the bottom of the angle to lightly scrape. 2 - Cut the PVC so you remove one side of the upper 2". Again just as you have already done, align the top of the rod to the top of the PVC when the bucket is level. This will give you a better indication of the downward angle of you bucket.
The pictures aren't the best, so it's difficult to see I used clear SCH40 1/2" PVC. That allows me to keep track of the steel rod when it is below the top of the pipe.
/ Bucket Level Indicator #11
Here is picture of what I described above. Works fine on level ground where the tractor wheels are on the same plane, but how often is that...
/ Bucket Level Indicator #12
Chim,
I have a Kubota L3010 with FEL that does not have the original level indicator on the bucket. I would really like to add one like you have designed. Would there be a way that you could show a couple of close ups pix of the dampener swivel and the eye bolt location? I have found all of the parts for this project except for the dampener swivel. I have been to Grainger and a couple of other parts suppliers for HVAC and can not seem to locate a piece like you have here. Any details on where you got such, a part number, etc. would be most helpful. Thanks!!!!!!!!
Rowdy
I'll get a couple pics tonight or tomorrow along with a small change to the pipe that should help.
/ Bucket Level Indicator #14
I made mine to stick out of the top of the pipe, my level mark is a painted stripe about a inch down the rod.
/ Bucket Level Indicator #15
Chim,
Rowdy
Heat the bottom of the rod and bend it into a L then drill for a cotter pin, no special parts are required .
/ Bucket Level Indicator #16
That's what I thought, must be an older guy thing to have an indicator, I've never used one and can tell when my bucket is level without moving the tractor, its just an acquired skill using it. Like you said the setting is only good for ground level, anything else and its inaccurate. Seems like a waste to me but that's just my opinion.
/ Bucket Level Indicator #17
Yep, my indicator is the flat bucket top. I have way more trouble with one side being too deep than bucket tilt.
Us old guys just need all the help we can get.
/ Bucket Level Indicator #19
When I bought mine I thought it would be a big deal but I never looked at it then I took it off because it was annoyingly noisy. I don't mss it
/ Bucket Level Indicator #20
The wheels of the tractor are on the same plane as the bucket more often then not. In fact in my opinion its rare in the course of a day that it's not on the same plane.
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
Freightliner Tender Truck - Adams Tender (A61307)
Freightliner...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F11JX133691 (A61165)
2018 Toyota Tundra...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
