Buying Advice buying advice
/ buying advice #1
gravelman
NH
Kubota 2650
im thinking of buying a subcompact tractor...18 or 22 hp..all wheel drive...belly mower, front end loader Im looking at Kubot and Massey Ferg..... i kinda like the Massey better so far...any advice would be greatly appreciated...
/ buying advice #2
I just went through the Compact Tractor purchase process. Man, there are lots of options out there. I looked at and drove them all LS, TYM, Mahindra, Kubota, and John Deere. I ended up with a new 2013 3032E John Deere. The Deere ended up being the best deal out there and the dealer network is absolutely the best. 0% financing was nice too. Never thought I would end up with the JD but I'm glad I did. I got the tractor, loader, brush hog and blade for under $19k. The Tier 4 emissions are being mandated now for lower emissions so if you can find one prior to that it will save you a lot of money and maintenance costs. Good luck and look at them all.
/ buying advice
thanks very much... i appreciate that info. so far the JD's have been more expensive than the rest but, as my brother says..you get what you pay for...most of the time. I have no JD dealer near me so that was a serious consideration.... good luck and thanks again
/ buying advice #5
Hi Gravelman,
I bought a 2012 JD 1026R SCUT in May this year. As many members will tell you, JD prices are routinely high. I ended up with Deere because I felt the operator station & controls were significantly easier to use & more refined than the others. This is a newer JD tractor - they took the Yanmar tractor & made improvements to it. You won't find this difference on some of Deere's older tractor models.
It's kind of a one-upmanship between manufacturers, just like with cars. Anyway, I encourage you to test drive as many as you can before deciding. There's no substitute for trying them out in person. Even before the financial dickering starts.
btw, EPA Tier 4 engine emissions began in 2013 for <25 hp diesel engines as well. So all new tractors from this point forward will have these engines. Deere's equivalent tractor is Model 1025R. I believe the dealer told me it has an exhaust particulate filter on it, and retarded fuel injection timing.
Good luck!
/ buying advice
thanks for that update.
/ buying advice
great info...i truly appreciate it. I had a NH with that computer transmission...forget that... i love my Massey but as you say....the JD's are hard to beat. thanks
/ buying advice
by the way...are you up in snowcountry, like near the Tug Hill????
/ buying advice #9
I am 70 miles north of the Tug Hill,we don't get any where the snow they do.I worked in central NY for ten years and seen it first hand.You can't believe it can snow that much.One storm I remember they got 54 inches in 24 hours.This year they got about five ft. over a couple days.
/ buying advice
i used to go up to Harrisville NY to the Viking snowplow factory and pick up plows for a dealer...i got caught in one of those storms once... drove 20 miles without seeing a thing except the tailights of a tractor trailer...wherever he went , i went. Nice country up there tho..Lowville, Boonville, Adams...love it in the summer. Thanks
/ buying advice #11
How many acres? What jobs do you intend to handle with your tractor?
/ buying advice
i have 5 acres..some flat, some fairly steep grades... mowing, brush hogging, pulling a dump trailer..snowplowing and blowing... occasional rototilling...
/ buying advice #13
Compare the features of the different tractors and see what u find.
The dealer support is probably as important as thing in the decision making process. A bad dealer will probably lead to a bad outcome.
Good luck in your quest!
/ buying advice #14
I'd begin my tractor hunt by finding out the pto horsepower requirement and weight of the snow blower since this probably will be the most expensive implement you buy. Front mounted or rear mounted blower? Once you have this information in hand, you'll be able to size your tractor accordingly.
Good luck.
/ buying advice #15
I knew I wouldn't be happy with the subcompact Massey Fergusson after sitting on it a few seconds because it just didn't fit me as well as the Kubotas. That ruled out the smaller Massey Fergusson's at least for me.
/ buying advice #16
I too am looking at buying my first tractor, but I am looking at used. I have sized out what I think I need to clear the snow and cut the grass. I am going to look at a tractor tonight and was wondering if there are any suggestions on what to look for. Obviously signs of leaking oil is a tell of trouble but are there other things I should keep an eye out for mechanically? This one does not have a mower but I do plan to use the rear PTO to pull a finish mower.
Thank you.
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
Komatsu D39 PX Crawler Dozer (A61166)
Komatsu D39 PX...
Crabtree 17yd Dirt Scraper (A64047)
Crabtree 17yd Dirt...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
ASSET DESCRIPTIONS & CONDITION (A59910)
ASSET DESCRIPTIONS...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
