Pallets in fields
   / Pallets in fields #1,073
Gotta be the wind .. Mine have fallen as well .. If I only had a "Pallet Grapple"
One of my pallets did contain a grapple only moments before the pallet field assembly test. The pallet was from Florida. When the pallet fell the temperature went from the 40s to the 70s. Coincidence?
   / Pallets in fields #1,074
Did the Florida pallet fall to the north?
   / Pallets in fields #1,075
Acknowledged, dragoneggs. You did indeed, put forth this avenue of inquiry and I thank you for reminding me and our colleagues.
The reason that I'm drawn specifically to the nails (and ancillary fastening devices) is the "patterns" produced by the placement of these fasteners; to wit... does the wood support the placement of the nails!
If it were a simple '3 nails at each junction betwixt slat & crosspiece- top & bottom' then I'd be inclined to dismiss them as simple pallet assembly conventions. However, I have observed substantively more nails have been deployed (on average) on every pallet in my possession. Why? Economics alone would say that a minimum number of nails be utilised in order to conservatively produce a pallet.
And what's up with the 'L' Shape. These are placed, seemingly, randomly throughout the structure... but are they?
First, I commend you on your review of the scientific literature. You have obviously read my article, "Nails and Wood: Perfect Complements in Pallet Construction," that appeared in the Journal of Pallet Economics in 1981. Well done, sir.
Second, you described the fasteners as being "L" shaped. Have you used a calibrated protractor to verify that the "bend" is indeed a right angle?
Third, absent any further information from sparc, you must rely on experimentation to "flesh out" your conjecture. You should determine the circumstances that result in replication of the "L"-shaped nails. Per the basics of experimental design, this should be a "blind test" -- you must use one of the aforementioned scientific devices to obscure your vision as you strike nails with a hammer. Your lab technician should record the temperature, wind speed, relative humidity, barometric pressure, etc. during the course of the experiment. For peer review purposes, you should post a video of the experiment to this thread.
Keep up the good work!!
Steve
Addendum
Unless you are ambidextrous, you should alternate the use of your right and left hands as you wield the hammer.
   / Pallets in fields #1,076
Sorry Joe but the expenditure on night vision goggles would not be required as a typical "Game Cam" would suffice. There are several TBN threads dedicated to this device and the pros/cons of the various manufacturers.
Plus you can record the experiment for austerity and review.
You may be able to requisition a scientific instrument from Pipette with the proper credentials.
Credentials? My FCC licence says I'm a technician; that should be worth something. Even so, it has been a hard winter for most North Americans, making the excess expenditure needed for scientific research devices nearly depleted, due to high heating bills. How about grants? If there are any grant writers in the group, we can get things rolling.
Joe
   / Pallets in fields #1,077
An image of the L shaped nail would be helpful.
   / Pallets in fields #1,078
Gotta be the wind?
That's it? No data collected? No soil samples? No photographs? No DNA testing? Is that your professional opinion? How did you arrive at that? You have absolutely no evidence indicating why the pallet was on on the ground and you jump to this conclusion.....gotta be the wind.....:banghead:
Did you do any testing at all for Snake flatulence? :cool:
   / Pallets in fields #1,079
Steve
I believe you overlooked the necessity of measuring the hammer head speed and angle incidence at the time of impact. This is crucial information.
   / Pallets in fields #1,080
Gotta be the wind?
And Dave claimed that you didn't have the intellectual capacity to be self-employed.
Steve
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
Bolt Bin (A57454)
Bolt Bin (A57454)
16 Inch Pohlar Chain Saw (A57454)
16 Inch Pohlar...
Single Cedar Glider (A57454)
Single Cedar...
Dump Truck (A59230)
Dump Truck (A59230)
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
