Pallets in fields
   / Pallets in fields #1,061
Gentlemen (and any Ladies in this astute discussion), I've had somewhat of an epiphany!
I humbly submit this for Peer Review.
Wagtail, yes back in post #229 I suggested that we look at the materials, construction, and geometry of said pallets. To date, I don't believe we have even established the pallets are constructed of wood. Likely they are... but we all know what can happen when we assume things as a given.
Gentlemen,
I hesitate to prepare a formal comment on the "composition conjecture" as this time.
We have not heard from either blueriver or txdon today. As you know, they were performing pallet experiments overnight.
They may have had a fundamental misunderstanding of the "blind test" in experimental design. While the principal investigator should have a bag over his head during the experiment, he does not have to don the bag until he reaches the site of the experiment. Likewise, he can remove the bag at the end of the experiment. I fear that blueriver and txdon are stumbling around their respective landscapes with bags over their heads.
On the bright side, their misfortune does serve as a useful lesson for junior scientists.
Steve
   / Pallets in fields #1,062
Oh, I did not make a observation on how they fell. I would look now but it is dark in that field and we all know nothing good comes out in the dark.
   / Pallets in fields #1,063
The Texas pallets have fallen - like the Alamo. Is this a normal progression or a failed experiment? We did have 40mph winds but I can't assume anything.
What a relief. I did not see your post before I expressed my concern about your well being.
Steve
   / Pallets in fields #1,064
I don't know .. The thought of a bag overt head does nothing for me
   / Pallets in fields #1,065
Odd Couple - "My Strife in Court" (Assume Scene) - YouTube
Acknowledged, dragoneggs. You did indeed, put forth this avenue of inquiry and I thank you for reminding me and our colleagues.
The reason that I'm drawn specifically to the nails (and ancillary fastening devices) is the "patterns" produced by the placement of these fasteners; to wit... does the wood support the placement of the nails!
If it were a simple '3 nails at each junction betwixt slat & crosspiece- top & bottom' then I'd be inclined to dismiss them as simple pallet assembly conventions. However, I have observed substantively more nails have been deployed (on average) on every pallet in my possession. Why? Economics alone would say that a minimum number of nails be utilised in order to conservatively produce a pallet.
And what's up with the 'L' Shape. These are placed, seemingly, randomly throughout the structure... but are they?
   / Pallets in fields #1,066
Gotta be the wind .. Mine have fallen as well .. If I only had a "Pallet Grapple"
   / Pallets in fields #1,067
Don,
Since you brought up a parallel to the Alamo, it occurs to me to ask, was Ozzy Osbourne anywhere in the vacinity?
   / Pallets in fields #1,068
Does the group have funding for night vision goggles? We're missing out on valuable data! :worried:
Joe
   / Pallets in fields #1,069
Maybe Google will fund the goggles
   / Pallets in fields #1,070
Joe
Sorry Joe but the expenditure on night vision goggles would not be required as a typical "Game Cam" would suffice. There are several TBN threads dedicated to this device and the pros/cons of the various manufacturers.
Plus you can record the experiment for austerity and review.
You may be able to requisition a scientific instrument from Pipette with the proper credentials.
   / Pallets in fields #1,073
One of my pallets did contain a grapple only moments before the pallet field assembly test. The pallet was from Florida. When the pallet fell the temperature went from the 40s to the 70s. Coincidence?
   / Pallets in fields #1,074
Did the Florida pallet fall to the north?
   / Pallets in fields #1,075
First, I commend you on your review of the scientific literature. You have obviously read my article, "Nails and Wood: Perfect Complements in Pallet Construction," that appeared in the Journal of Pallet Economics in 1981. Well done, sir.
Second, you described the fasteners as being "L" shaped. Have you used a calibrated protractor to verify that the "bend" is indeed a right angle?
Third, absent any further information from sparc, you must rely on experimentation to "flesh out" your conjecture. You should determine the circumstances that result in replication of the "L"-shaped nails. Per the basics of experimental design, this should be a "blind test" -- you must use one of the aforementioned scientific devices to obscure your vision as you strike nails with a hammer. Your lab technician should record the temperature, wind speed, relative humidity, barometric pressure, etc. during the course of the experiment. For peer review purposes, you should post a video of the experiment to this thread.
Keep up the good work!!
Steve
Addendum
Unless you are ambidextrous, you should alternate the use of your right and left hands as you wield the hammer.
   / Pallets in fields #1,076
Credentials? My FCC licence says I'm a technician; that should be worth something. Even so, it has been a hard winter for most North Americans, making the excess expenditure needed for scientific research devices nearly depleted, due to high heating bills. How about grants? If there are any grant writers in the group, we can get things rolling.
Joe
   / Pallets in fields #1,077
An image of the L shaped nail would be helpful.
   / Pallets in fields #1,078
Gotta be the wind?
That's it? No data collected? No soil samples? No photographs? No DNA testing? Is that your professional opinion? How did you arrive at that? You have absolutely no evidence indicating why the pallet was on on the ground and you jump to this conclusion.....gotta be the wind.....:banghead:
Did you do any testing at all for Snake flatulence? :cool:
   / Pallets in fields #1,079
Steve
I believe you overlooked the necessity of measuring the hammer head speed and angle incidence at the time of impact. This is crucial information.
   / Pallets in fields #1,080
Gotta be the wind?
And Dave claimed that you didn't have the intellectual capacity to be self-employed.
Steve
2004 CATERPILLAR 320C L EXCAVATOR (A60429)
2004 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
