I don't have a welder -
/ I don't have a welder - #3
Looks like firewood really..really dry for such splitter.
/ I don't have a welder - #4
Notice it is all straight grain soft wood. It has a purpose. If that head weighs 50-100# it can pack a good wallop. I would have a solid piece of large trunk wood as a base instead of the table this guy has, too much bounce. A smaller version to make small kindling would be more valuable for me. Most of what he is splitting I only split once. Those small pieces burn too fast.
Ron
/ I don't have a welder - #5
Notice it is all straight grain soft wood. It has a purpose. Those small pieces burn too fast.
Ron
So true, he would be constantly feeding his fire like a boiler on a locomotive with those small pieces. Maybe he just uses those for kindling. I would like to see him try splitting a big ole piece of red oak with that rig.
/ I don't have a welder - #6
Hmmm, I may try something like that.......except it'll be for forging metal purposes.
What is that guy doing? Making shingles?
/ I don't have a welder - #8
It takes allot of force or ton's of pressure to split wood, This tool doesn't look like it has either, Of-course if the wedge end weigh 75-100 lbs and free-fall dropped from about 4 ft. it could very well split wood, but looking at it with almost no effort to pull it down I'm not convinced, It looks to be rigged with a torsion rod & spring, but this does nothing more than to help with balancing and easy lifting, I just cannot see any way possible without pressure or force applied that this can actually work,:cool:
There is a tool made for slicing through several inches of paper and is made on the same principle as this so called "wood splitter, only it has a recoil spring and much sharper blade,
/ I don't have a welder - #9
I like how fast he splits but I enjoy having all of my fingers ....
/ I don't have a welder - #10
Let's see him post back in a few months and count his fingers. That contraption is more dangerous than the wheel of death splitter.
/ I don't have a welder - #11
hahaha well said gary:) ill keep my homemade splitter. That wheel of death splitter is one scary #|+!_}{!!
2022 TrailMaster Gas Cart (A61574)
2022 TrailMaster...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
2006 Ford E-450 (A64119)
2006 Ford E-450...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
CASE INTERNATIONAL 2020 - 25' FLEX HEADER (A63291)
CASE INTERNATIONAL...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
