why do snowblowers have a maximum recommended HP?
/ why do snowblowers have a maximum recommended HP? #1
alltherage
Western NY
2011 Cub Yanmar EX2900. 1939 Farmall A, 1940 Farmall H, 1959 Oliver 770
is this because of the shear pin strength? I'm looking at a lucknow 52" tomorrow and the HP recommendation is 12-20 on lucknowproducts.com. Will this really be an issue with a 29hp hydrostatic tractor? Also, the 52" width will make it a couple inches short as the tractor is 57" wide at the rear tire treads. Will this be a major issue as well?
/ why do snowblowers have a maximum recommended HP? #2
The shear pin should protect the blower from any excess of power if the auger or impeller get jammed. 12-20 hp is more an indicator of the general ruggedness of the unit I think. The gearbox on the blower and chains, for example, are rated to handle up to 20 hp.
I think I would look for a wider blower, something one foot wider (total) than your tractor. You will be living with the blower for many seasons, may as well have what you really need than to just get by. On any turns, it will be much more than just 2-3 inches snow on each side that the wheels will be packing down.
I always thought a 6 foot blower would be too much for a 29hp tractor so I automatically started looking at 5 footers. Should I consider a full 6 footer?
/ why do snowblowers have a maximum recommended HP? #4
With HST tranny I would look at something wider than your tires in this case 6 foot. Blowers work best when there is a steady stream of snow so adjusting speed with the HST helps this a lot Vs manual tranny.
/ why do snowblowers have a maximum recommended HP? #5
I agree...should be wider than your tires. I run a 74" blower with 30 engine HP (22 PTO HP) and HST with no power issues at all. I do have to be careful not to sideswipe things when going forward because I have narrow tires...my width over the tires is about 48" and my FEL bucket is 54". In my case a 60" blower would probably be a better match because of the narrow track; with your wider track I don't think it would be a serious issue.
/ why do snowblowers have a maximum recommended HP? #6
You really do want the blower to be a bit wider than your tires. It will especially be noticeable when making turns(sharp or gradual). I have heard of people adding wings to the blower which may eliminate this issue.
/ why do snowblowers have a maximum recommended HP? #7
Here is what I did. Not expensive - $50 for the wings cut and bent to shape.
/ why do snowblowers have a maximum recommended HP? #8
I have a 75" Meteor pull type on my DK35SE HST (38 gross HP) with around 28 PTO HP. We get frequent heavy, wet snows of 4" to 8". It has no trouble clearing at close to maximum speed in mid range. At times I've cleared very wet, dense old snow up to 18" deep(clearing neighbours' areas that have been left uncleared for a few snows). That requires slowing to a casual walking pace so the tractor can handle it. The HST makes it easy to adjust the forward pace while maintaining full PTO RPM. A gear tractor can do the same by operating in a lower gear.
I was concerned my tractor would not handle the larger blower but my dealer assured me it could. As others noted, it is nice to have the blower wider than the tractor.
I see your tractor is rated at 22.7 HP on the PTO. I get the impression my tractor is not anywhere near the 28 HP capacity for most of my clearing of a normal 6" snow -3 celsius and below (i.e. not real heavy snow).
Looking at the Lucknow specs for pull-types, it appears the 5' and 6' units have the same blowers with four 22" diameter, 8" wide blades. The blower is where most of the power is used. My 75" Meteor's blower has four 23" diameter, 8" wide blades and would use a bit more HP (assuming it is full of snow) than the Lucknow.
I'd be inclined to go with the 6' unit. Hopefully there are others with similar snow conditions and HP as yours who can give an opinion based on actual experience.
/ why do snowblowers have a maximum recommended HP? #9
No, look at 5 footers. 52" is only 4' 4" not 5' or 60". I run a 74", 6' 2", on my 45 hp HST and it's a good match but way to much for a 29hp tractor. Blowers are also rated for PTO hp, are you 29 engine HP or 29 PTO HP? If you have 29 engine hp, you're closer to the rating than you think. Either way, you want to at least cover your tracks. I don't think over powering a blower slightly is a big deal but putting a blower rated for 20 hp on a 50 hp tractor means that you'll be able to over stress it by running to much snow through it too quickly. If you try and move too fast with a 20hp tractor, the engine will bog down long before the blower is over stressed, not so with a more powerful tractor. Regardless, covering your tracks is the most important thing so it's rarely an issue.
I looked up the numbers...our tractor is 28.7 engine HP and 22.7 PTO HP. So it seems like, ,based on the last few posts, that 72" blower may be too much. Maybe the 60" is the best option, or the 52" with wings.
/ why do snowblowers have a maximum recommended HP? #11
Get the 60"
Don't do the wing thing...
You will inevitably end up with a less than perfect setup and will always have a spoil pile that the wings leave behind.
Had wings on my 51" front mount and ended up trading the blower for a 63"
Sent from my iPhone 5s 64Gb using TractorByNet
/ why do snowblowers have a maximum recommended HP? #12
Get the 60"
I would definitely agree with that...
/ why do snowblowers have a maximum recommended HP? #13
I also think going with a wider blower is better than adding wings since the blower's auger works the whole width to get the snow to the centre blower.
Again, the blower fan size has more bearing on the HP requirement than the units width. I looked at Lucknow's data for regular blowers (i.e. not pull-type). The 5' and 6' have the same 22" x 8" deep fan and Lucknow's recommended HP for both is the same--20 min. to 35 max.
The Yanmar site has a brochure showing regular blowers. The 54" recommends 15 to 25 HP and 64" recommends 15 to 35 HP. Both have fans 22" diam x 6" wide blades. I wonder why the 54" has a lower maximum HP rating than the 64" but the same minimum rating. Yanmar has a 74" unit with recommended 30 to 50 HP. The fan size on this is 24" diam x 8" wide.
Unless you have large, heavy snow dumps I think your tractor would handle a 6'. Your 3 point will easily handle the weight and it's no problem simply to go a bit slower with an HST. You would definitely not have a problem with the 60" and would be best not to go smaller than that.
/ why do snowblowers have a maximum recommended HP? #14
Lots of solid manufacturers make sizes between 60 & 72". I think those would be well suited for you.
For example Pronovost makes a 62" & 68" width, Landpride makes a 64", etc.
/ why do snowblowers have a maximum recommended HP? #15
It is rated for the gearbox , or right angle box .
Ok, thanks a bunch everyone. I'll wait for something in the 5'-6' range. I know Meteor makes a 68" as well. I looked at the lucknow yesterday and it's a real shame because it's like new...just too narrow.
Take care.
