Battery for 2615
/ Battery for 2615 #1
Blue_Sky
Lower Alabama
2006 2615 4WD Mahindra
My current battery has a CCA of 540 and on cold mornings it is hard to start requiring a battery charge on occasion. 540 CCA is what came on it, but not the same battery. I am thinking of getting a larger size battery with 700 CCA. My question is - can that hurt the tractor?
Thanks
/ Battery for 2615 #2
I have a 2615 also. When my battery needed replacing I got the highest CCA battery that would fit in the battery box. My tractor turns 10 this year. still running fine. Alternator keeps it charged with no problem. I have extra lights on the top front of the cab, a back work light, a yellow flashing strobe, and a 12V ceramic heater.
I also just bought 2 new batteries for my 1T dump truck and went with the highest CCA for that also.
/ Battery for 2615 #3
Absolutly not. A higher CCA battery will just provide more amperage if the starter needs it. It is still a 12 volt battery regardless of the CCA. If a higher CCA battery fits in the machine and the + and - posts are in the same location you are good to go.
/ Battery for 2615 #4
Burzynsr is correct. Buy the highest CCA battery according to cost, physical size, terminal post type & location and method of securing. (some batteries have a lug on the bottom of the battery for a clamp, others don't)
/ Battery for 2615 #6
If you haven't done so, consider thoroughly cleaning, and painting your entire battery compartment with a bed liner, or some type of undercoating material. I hadn't done so, and consequently when I failed to place the cell caps in a water tight position, the leakage, especially due to vibration, caused a lot of corrosion. I looked for a battery case which would fit in my 2615, and couldn't locate one. A case would provide longest term protection.
I've also installed a float charger. My Wal*Mart battery is going on six years of age, and still starts the tractor as well as when it was new.
/ Battery for 2615 #7
Tupperware makes all sizes of containers. If your battery has a base size of 12"x9" TW makes a size for that. All you need is the bottom part siliconed or bolted to tractor. I used "Chassis Guard" in mine. That stuff is liquid goop that dries like a hardened missile silo.
/ Battery for 2615
Great Idea!
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
CATERPILLAR 48" QUICK ATTACH PALLET FORKS (A65056)
CATERPILLAR 48"...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Wheel Loader Root Rake (A68134)
Wheel Loader Root...
