Ford 1910 770B loader question?
   / Ford 1910 770B loader question? #1
Welwood
Jacksonville, Florida
Ford 1910
I have a Ford 1910 with 770 loader that I am replacing the ridgid hydraulic lines
on the loader. Anyone have any tips/suggestions on start-up i.e. priming, air in lines etc.?
TYIA
   / Ford 1910 770B loader question? #2
After you get all of the lines on, overfill the hydraulics by 1/2 gallon and cycle the cylinders open and closed 4-5 times. They will bleed and purge themselves. Check your hydraulic level and adjust.
Thanks much TTech,
This is not usually my kind of luck, sounds easy enough to me. I assume you cycle running vs static, correct?
Thanks again.
   / Ford 1910 770B loader question? #4
Thanks much TTech,
Thanks again.
Yes, with the tractor running, cycle the lift and bucket cylinders several times.
Sorry, I realized after I asked it had to be running. Someone once said theres no such thing as a
stupid question............only inquisitive idiots.:D
   / Ford 1910 770B loader question? #6
No problem. One of those things that once you've said or read it, you realize what you actually said.
GENIE S-60 MANLIFT (A58216)
GENIE S-60 MANLIFT...
Caterpillar 1430D Backhoe Loader (A57148)
Caterpillar 1430D...
(5) Seats (A57149)
(5) Seats (A57149)
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
2014 Ford Taurus (A56859)
2014 Ford Taurus...
