Ford 1910 770B loader question?
   / Ford 1910 770B loader question? #1
Welwood
Jacksonville, Florida
Ford 1910
I have a Ford 1910 with 770 loader that I am replacing the ridgid hydraulic lines
on the loader. Anyone have any tips/suggestions on start-up i.e. priming, air in lines etc.?
TYIA
   / Ford 1910 770B loader question? #2
After you get all of the lines on, overfill the hydraulics by 1/2 gallon and cycle the cylinders open and closed 4-5 times. They will bleed and purge themselves. Check your hydraulic level and adjust.
Thanks much TTech,
This is not usually my kind of luck, sounds easy enough to me. I assume you cycle running vs static, correct?
Thanks again.
   / Ford 1910 770B loader question? #4
Thanks much TTech,
Thanks again.
Yes, with the tractor running, cycle the lift and bucket cylinders several times.
Sorry, I realized after I asked it had to be running. Someone once said theres no such thing as a
stupid question............only inquisitive idiots.:D
   / Ford 1910 770B loader question? #6
No problem. One of those things that once you've said or read it, you realize what you actually said.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
