GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #1
PHILIP8N
Indianapolis
Kubota L3940 Kubota GR2120 Ford 8N
Have 5+ years on my battery, want to plan for replacement. Printed on oem battery NX110-5MF, 80D26R, 582CCA. What 'group' number have you guys used as replacement on these models with no modifications? Thanks. Philip.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #3
I wouldnt plan to soon as my last two grand l batteries went 9 and 10 years.one in A 4610 and one in a 34 hp
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #6
5 years? I have one that's 11 that's fine and another that just died at 12 years old. I think you might get a few more years out of your battery. ;)
I am preparing. I like to know what size I need before it goes click on a cold Sunday morning and none of the stores can cross reference it. Thanks. Philip.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #8
It's a 26R
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #9
Interstate offers many drop in batteries for Kubota.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #10
Size 24 is what I bought for my L3540.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #11
I agree, when it dies, take the battery in and get the biggest, heaviest duty diesel battery they have that will fit into the space.
As long as you either use the tractor weekly, or put it on a charger occasionally, they should last a long time beyond 5 years.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #12
Yeah, according to the OEM number, it is a group 26R, but that is a very uncommon (translate - expensive, hard-to-find) battery, so I did like others and just measured for the largest that would fit. Be careful when you measure - my L4330 has small protruding knubs on the lower "tray" where the hold-down rods insert. These knubs are the limiting width factor but they are easy to overlook when measuring. Otherwise, almost any battery would fit. I think that the OEM cables are even long enough that it doesn't matter which terminal arrangement you get, but check yours to be sure.
- Jay
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #13
A guy at the interstate battery store told me that he would buy the battery with less CCA if they are both the same physical size. To get extra cranking power the plates are longer. That means the plates are closer to the bottom of the battery and can short out sooner as the battery plates degrade. Personally I would look into getting a AGM battery as a replacement.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #14
26R is a very common size. My Massey and Kioti use it.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #15
I'm replacing my battery and was wondering do I put any type of grease on the terminals or not? If I do, what should I use.
Thanks for the all info here on "upping" the battery size.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #16
I always put on a light coat, smeared all over everything. I don't think that what kind is terribly important, vaseline, axle grease, whatever's in the grease gun. The main idea is just to provide a barrier between moisture/air and the posts and terminals.
- Jay
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #17
I have been using No-ox-Id now for about 35 years on battery terminals. I got started using it commercially at work on stationary batteries.
I will guarantee you will never have a corrosion problem if you use it.
Rust Preventatives Stop Rust with Corrosion Resistant Barrier Coating
NO-OX-ID A-Special Electrical Grade Conductive Grease (2oz) - $4.50 : Illumination Supply, Quality Flashlights and More!
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #18
Thanks for the info on greasing battery terminals. Battery in, up and running & just finished mowing. Thanks again.
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #19
Thanks for all your help and suggestions. Got 'er up and runnin'
/ GrandL battery replacement, L3940, L3540, L4240, L5040, L5240, L5740 #20
No idea if we're still keeping score. However my L48TLB with factory battery after 16 years seems to want a new one. Still turns over but needs a top off with a charger in this cold weather. I expect that GS Nippon Denchi battery is likely worth whatever premium the OEM paid. FWIW it is an 80D26R-MF which translates to a 24 form factor here.
