Working My Way There
/ Working My Way There #1
Dan Hunter
Enid, OK
2012 John Deere 3720 eHydro
I've often said, "If I didn't want to stay married I'd move to the ranch." Our place has no structure on it. Never did. Just an old Tulsa Airplane Company Tandem Spartanette IIRC and it's been gone for years. When we head out to work on clearing red cedar and improving the place for deer habitat, we're time and energy limited.
Well, I'm working on a compromise. In April, we're having a 30 x 40 Mueller steel building installed. It'll allow me to get all the ranch-related hardware stored out there and still have room to "camp" out of over the weekends. I'll keep it quite "spartan" to avoid having the place taxed as a dwelling but have the slab poured with plumbing in case we later pull the trigger.
We chose the site because it's easily accessible but still has the potential for a fairly commanding view. Most of the trees have been taken down with a chainsaw but I'll come back and shear the stump flush and we're bringing in sand to level the site before pouring the slab.
/ Working My Way There #2
Isn't it amazing how much work we create for ourselves when we move to the country. Good luck, and enjoy.
/ Working My Way There #3
Dan, that scrub brush and small oaks can be a real chore to clear, but it looks like you have a plan. Do you have any ponds or water on your acreage? Water really helps to draw in the wildlife.
Making work...this is the one thing I excel at above all. For instance, I've already started planning a pizza oven.
I have a place where a pond should be after the drought ends and I kill more red cedar.
/ Working My Way There #6
Good luck and keep us posted. :thumbsup:
I put a down the the shop. Dark green roof with taupe walls.
It's been to cold too get anything done out there but I did call the county clerk and confirmed "at this time, Major county does not require permits on any activity outside of incorporated areas." It sounded as if she'd said it many a time.
/ Working My Way There #9
Don't know what it's like in your area but around here any isolated rural building containing equipment will be burglarized. Give security some consideration in your building plans.
/ Working My Way There #10
It oughta look real fine 'cause that's the same colors we picked. Used dark green on the East side to warm it in winter, light tan elsewhere. Dark green roof trim & soffits. But the actual roof bright white (and 12' tall walls) for cooler summers.
Bob
A highway patrolman lives across the street.
/ Working My Way There #12
If you're not concerned with break ins, you might consider a bay of windows on the South. A bit of solar heating helps a lot in the Winter; especially when you don't have any heat in the building. My shop doesn't, and it's always about 15 degrees warmer than the outside temperature(it's insulated) in the Winter.
Ready for sand/slab/construction
/ Working My Way There #14
:thumbsup:
/ Working My Way There #15
You got cedars, you got water. Now just find it. I would witch the place first and mark where the water is, then build near it but not right on top of it.
/ Working My Way There #18
Dan, looks great! Now you have a few more reasons to "go to the farm":laughing: and be comfortable going
Garage doors this week will make it enclosed. I'll seal the floor ASAP and then start moving in.
/ Working My Way There #20
:thumbsup:
