does anyone own a jd 5085m?
/ does anyone own a jd 5085m? #1
southerndeere
Well after I found out no dealer supports mahindra in my area anymore I found a 2011 5085m with 760 hours. Approved by my bank but before I pull the trigger I just wanna ask one more time if anything has anything bad to say about these tractors. I'm always aprehensive when I go to spend a lot of money an I'm sure the first month or so I'll feel sick. So basically I'm trying to find someone to talk me out of it.
/ does anyone own a jd 5085m? #2
My neighbor has one. I believe his is a 12. Had a few issues when he first go it. His was the first year of tier 4. Other then the few issues he's been real happy with it. I spent a ton of time researching the m and e series. In the end I went with the e. If money wasn't a problem I would have bought the m. I would check to see if that tractor has any of the emission stuff on it. If it doesn't have it, that's another plus.
They also haave a 5085e but the loader didn't look as heavy duty. I think it was a 553 loader? It did have the 3rd loader valve I believe tho. Whhich would be noce if I ever wanted to add a grapple
/ does anyone own a jd 5085m? #4
I got my e with a h260 loader and 3rd function. The m has a little more hydrulic output. I think 2 or 3 GPM more. It also has a electronic 3 point. I take it the 85e is a 13 or 14? They can put the better loader on the e. What do they want for the m compared to the e?
The 13 e is right at 5000 more if I remember right.
/ does anyone own a jd 5085m? #6
They have 0% on the e's for 5 years right now. I couldn't find much info on the new 85e's. They just started making them in 13. Took the place of the 83e. The m and the new e's are lot closer in comparison now. What's your plan for the tractor?
We have a small cattle farm. Move hay mainly. Raking tedding. Bush hoggings. I have a 5055d right now an we bale 4x 5 bales. But looking to upgrade to a 5x6 baler so I'm gonna upgrade my utility tractor also
/ does anyone own a jd 5085m? #8
Either tractor would do a great job. I think you'll find the economy pto usefull. As long as the m is in good shape and you don't mind a used machine, I think you'll be very happy with it. They could add a 3rd remote for you. What trans was in the m?
I agree. I also like the dual speed pto. We have a couple older implements that are 1000 rpm
U were right 0% on the e models. An they have a 5085e with the 3rd loader function like I want. But I made a mistake an stopped by the kubota dealer. They have 0% too an the salesman nearly sold me on a 8560 on the spot
/ does anyone own a jd 5085m? #11
I was in the same spot a couple moths ago. After sitting in both tractors and really looking them over good, I felt the JD was the better tractor for me. I could of bought a 8540 for a lot less then the deer. It had been sitting on the lot for awhile. Wasn't impressed how faded all the paint was for a new tractor. I also feel the JD cab is laid out nicer. Let's hope I made the right choice, feel like a guinea pig with 85e. Not much info on such a new tractor.
Well I have until theend of the month to make a decision. Deere will give me what I want for my 5055d. Kubota is a little under but there tracyor is cheaper
Wow so many choices. Saw the case dealer has 0% an heard on the radio new holland is doing the same
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
WHITE 2-185 TRACTOR (A63291)
WHITE 2-185...
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2014 Generac QT04854 Anax 48kW Natural Gas Generator (A61572)
2014 Generac...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
