3-Point Hitch Quick-Coupler for 3032E Yes or No
/ Quick-Coupler for 3032E Yes or No #1
kcflhrc
Kansas
2013 John Deere 3032E
Just inked the deal on a new 2013 3032E, Dealer is asking me if I want a Quick-Coupler for the 3 pt hitch for the implements. I will be getting a brush hog and blade with it.
Thoughts on this accessory for $350 ???
/ Quick-Coupler for 3032E Yes or No #2
Is that the new name for I-match?
Yes, I believe so
/ Quick-Coupler for 3032E Yes or No #5
You will regret not getting it . Saves a bunch of hassle hooking up .
Thanks guys for the responses. $350 over 5 years with 0% financing isn't going to break me. Decision made, I will get it.
/ Quick-Coupler for 3032E Yes or No #7
Good call...money well spent. Just make sure any implements you buy in the future are iMatch compatible.
/ Quick-Coupler for 3032E Yes or No #8
Is I-match the same as a Quick Hitch?
I know the i-match is John Deere specific, looks like this
/ Quick-Coupler for 3032E Yes or No #10
iMatch is a brand name for the quick hitch John Deere sells.
/ Quick-Coupler for 3032E Yes or No #11
/ Quick-Coupler for 3032E Yes or No #13
I've often wondered about those lower arm extensions. Are you happy with them? And rough cost compared to imatch or a quick hitch. I have a quick hitch and really like it because I have a hydraulic top link. Cost was about $200 in 2005 or so. I decided I couldn't build it for that price and bought it. I like my quick hitch but find I need to watch for pto shaft interference with the tph all the way down. That and I need to rebuild all my pins and pin holes as they are wore out, are about the only issues I have.
/ Quick-Coupler for 3032E Yes or No #14
I think you'd be smarter to get the extensions Deere offers for their lower arms on the 3pt hitch.
Where can I find details on these extensions? I do not see anything listed for the 3032E under the "Build your own" options
/ Quick-Coupler for 3032E Yes or No #15
I looked in the parts book online and couldn't find anything for your tractor. Didn't find anything for a 3520 either but if you look up a 4410 under "hitches" and then "draft link telescoping attachment" you'll see what Dapolksjj is talking about.
/ Quick-Coupler for 3032E Yes or No #16
I did find the option for "Telescoping draft links" under the 3033R build page. But I did not see any such option for the 3032E. I wish they offered those for the 2-series tractors as well.
/ Quick-Coupler for 3032E Yes or No #17
But will it fit say a Land Pride implement?
It should fit about all modern implements. Landpride has their own quick hitch that looks about like the JD imatch. There is actually an ANSI standard on quick hitch dimensions, so most manufacturers are following that standard.
The thing I don't like about the Pat's easy change system that you linked, is that you still have to get off and mess with the top link. With the iMatch and the others you don't have too.
/ Quick-Coupler for 3032E Yes or No #18
Or if you have the money you can go Delta and not have to worry about incompatibility with your old non quick hitch implements. But like I said, IF you have the money.
http://www.deltahook.com/
/ Quick-Coupler for 3032E Yes or No #19
I linked? Better check again. I don't see Pats mentioned till you brought it up.
/ Quick-Coupler for 3032E Yes or No #20
The forum probably linked it for you. Go back and look at your post.
That Delta system would be nice. I wonder if it comes in green:)
Massey Ferguson 2605 (A64126)
Massey Ferguson...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2010 Case 580N (A60462)
2010 Case 580N...
2000 Hino (A64194)
2000 Hino (A64194)
2021 Deere 35G (A64126)
2021 Deere 35G...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
