b3200 injector shims
/ b3200 injector shims #26
Have you made any progress with your starting issue?
Someone mentioned on this forum that you could hold the key to the right after starting. This keeps the glow plugs energized. I used this method on Saturday and there is much less smoke and roughness. My tractor had not been started in two weeks. 😎
Someone mentioned on this forum that you could hold the key to the right after starting. This keeps the glow plugs energized. I used this method on Saturday and there is much less smoke and roughness. My tractor had not been started in two weeks. ��
I haven't started the tractor in a couple weeks, but I've got to move firewood this weekend so I'll give it a shot.
/ b3200 injector shims #31
Keep in mind that if the tractor is under warranty, any changing of the timing by the owner will void the warranty. Is that something you want to chance?
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
Swict QA 60" Bucket (A64912)
Swict QA 60"...
2014 HIPOWER 310 Generator (A67714)
2014 HIPOWER 310...
2019 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2019 CATERPILLAR...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
