Buying Advice How important is a Backhoe Thumb?
/ How important is a Backhoe Thumb? #1
smitesmash
Whidbey Island, Wa
JD 650 (sold) Kubota L45
I'm getting ready to pull the trigger on a new Kubota L45.
The thumb kit adds $1900 to the total cost. I notice that most backhoes I see around don't seem to have them.
I've rented a trackhoe a couple of time, and each time I used the trackhoe thumb. But I don't know if this is something that I used because it was there, and would not really have missed if it was not there.
I have an enormous number of 3" - 6" DBH alder tree stumps to remove. Alder is pretty shallowly rooted, so I imagine based on that that this would be something that I would use every day?
Thoughts and advice?
/ How important is a Backhoe Thumb? #2
All depends on your needs of course... I have gotten pretty decent usage with my mechanical thumb. It has been useful and saved my back some too. If I had a hydraulic one, I would be even happier and use even more. I suppose it could be considered a luxury and when you put a dollar amount on it weighing vs. benefit that could result in a tough call. All that said, in general (not limiting this to tractors) I have always liked going a little overboard on the options because I end up using them and am happy. The options are also a great selling point should you go another direction. If you can afford it, don't deprive yourself of a simple pleasure that isn't bad for you! :D
/ How important is a Backhoe Thumb? #3
Adjustable/retractable, manual thumbs/kits seem the alternative to a deluxe setup, priced accordingly, and one has the bucket's 'ripping' power either way, perhaps well beyond the gripping force of the add-on (get real numbers on both if you can). Back-hoe size/muscle, reach etc should matter, but IMO a thumb won't gouge/dig up gnarly stuff anywhere like say a ripper tooth, tho' it should easily grab onto more than your boom can lift once you've dug out ...
To me, transporting one or several clunkers of any size seems so much easier with a grapple on a FEL than dragging them around on a BH stinger (tho' grapple's weight can reduce lift capacity on some compacts and may demand stability and a sturdy FEL frame/mount if one were to get 'rammy' at times.) Anyway, BTDT with autumn olive (jumbos!), poplar, and willow anchored in well settled sand with lots of gravel and grassy undergrowing roots. btw: for that reason my QA grapple awaits only an appointment to have front hydro lines/QDs installed.
I suggest you look into a ripper tooth someday if your stuff doesn't come up easily with the std BH bucket, often easier to muscle up or bust one root at a time with what 'ripping power' you do have. Whether you'd prefer a manual or powered thumb might just be between your wallet and how often you might want to adjust the gap between the bucket if you go there. The extra reach vs a grapple might be handy in the thickest-grown spots. ;) Pics to come when you get 'er rigged up, right?
Sorry, I should have added.
some sort of ripper/root rake/skeleton grapple will be my first attachment. Still working out which one it will be.
I feel that I should get some amount of drive time on this thing, before deciding that I need this additional stuff.
however getting the whole tractor in place to pull out some of these stumps might not be very feasible. this attachment is one of the more cleared areas that I will get to deal with.
/ How important is a Backhoe Thumb? #5
See if you can get a quick coupler on the excavator you will soon get tired of whacking bolts with a hammer. I have a 14 t crawler excavator and I am very happy that I dont have to beat the bolts to change atatchment
/ How important is a Backhoe Thumb? #6
I have a hydraulic thumb on my L45, at first I did not think I wanted it but the dealer talked me into it and three rear remotes, best decision I ever made on a tractor. If you are clearing property, you want a thumb on your backhoe, if you want it to be easy and less time consuming get a hydraulic thumb. My thinking was on a $40k tractor I did not see a $1600 cost (my cost) as a significant cost delta in the end.
/ How important is a Backhoe Thumb? #7
A hydraulic thumb has its place, which is your intended purpose. I have operated excavator and backhoe professionally for over 25 years and normally, thumbs just get in my way, except for pulling and pill g stumps along with grabbing and piling brush. Well worth it for that. An inexperienced operator will love it for digging rocks too. Probably money well spent. I also concur on the backhoe bucket quick attach.
/ How important is a Backhoe Thumb? #8
I have the little brother to the L45, my B26 with hydraulic thumb is amazing at what I can do with it clearing saplings, piling them with the hoe/thumb then pushing them into a pile with the FEL. A grapple would be a nice thing to have on a root / rock rake bucket but I manage ok with just the FEL. I am sure I can push much more than I could lift and carry.
I can back into a thicket like you have (mine are sweet gum) and with the hoe, uproot then using the thumb pick up the tree and move it to the side piling them a bit. Just work a circle that I can reach then raise the stabs and with my extension rod, reach forward, hit the HST pedal and back up some more to get into a new circle and start over. After clearing out an area, I then use the FEL to push everything into a pile, sometimes setting up and using the hoe and thumb to pile the trees up a bit better on the burn pile. It works great for stumps and logs that I cant quite get to go into the pile the way I want them (remember I don't have a grapple).
The thumb is great for lifting things like rocks also. I will pick up the heavier ones with the thumb and place them in my RTV to haul and dump rather than try to scoop them up in the FEL.
Get the HST drive on your tractor as it is much easier to operate it from the backhoe position than a gear drive
/ How important is a Backhoe Thumb? #9
I have operated excavator and backhoe professionally for over 25 years and normally, thumbs just get in my way.
That is why I like the hydraulic thumb, with it folded back along the dipper, it is out of the way whereas a mechanical/manual thumb would sometimes interfere with digging or other activities OR would not be in the right position to pick up the size material that you are attempting and would need to be manually adjusted. Having not to do that many times is well worth the extra cost of a hydraulic thumb. When installed correctly, they have the same pressure of bite as the bucket so no danger of damage to either one when using the other and clamping/digging force is equal. I sometimes use the thumb to lift/sort out roots of saw briars so I get the roots and not much dirt as I would if digging them with the bucket. There is just so much more versatility of use on the backhoe when you have a hydraulic thumb.
You guys rock. I post a question at near midnight my time, and before my morning coffee is ready, I have some answers.
Based on this, I'm going with the thumb.
Thanks all.
/ How important is a Backhoe Thumb? #11
I have a mechanical thumb and have used it alot. The problem is, after you use it, it is in the way for digging out the next boulder etc, so you have to get off the tractor and pin it up.
If I had it to do over, I would have spent the extra money and went with a hydraulic thumb.
I have alot of big rocks, so I dig them out, pick them up with the thumb, then transport them hanging from the hoe and place them, it is time consuming, but it works...I really want a grapple for the loader, and I am already plumbed for it, that would be tha cats meow for my situation, I could dig up rocks then just drive around and pick them up with the grapple, and put them where they need to go .
/ How important is a Backhoe Thumb? #12
...Based on this, I'm going with the thumb.
That is a great choice. I have both thumb and a grapple on my TLB and they do different tasks. Both are valuable and very useful.
I think you want a general-purpose machine and these add a lot of capability. My hydraulic thumb has never gotten in the way of anything I wanted to do, but has added a lot of versatility to the hoe. There is a world of difference between a mechanical thumb and a hydraulic one. The mechanical thumb can easily get in the way of a lot of operations and just does not have anywhere near the capabilities of a hydraulic one.
/ How important is a Backhoe Thumb? #13
I suppose if a guy is simply digging trenches or septic tanks and such, a thumb would not be that handy. But for general property clean-up, it is a must have in my book. A mechanical thumb is a step in the right direction, but just bite the bullet and get the hydraulic if your budget allows. Then a 4-n-1 on the front and also a root rake grapple to swap on occasionally and you'll hate to ever shut off your machine for all the fun you will be having.
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2009 Peterbilt 367 Flat Bed (A64047)
2009 Peterbilt 367...
New/Unused IRGC40 Mini Golf Cart (A61166)
New/Unused IRGC40...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
