John Deere 4105 starting problem (?ignition switch?)
/ John Deere 4105 starting problem (?ignition switch?) #1
hyperrust
SC
Kioti DK40, Bobcat CT2025
I recently began having trouble starting my 4105. I was in the field and had to shut it off, and when I tried to turn it back on I had to turn the key back and forth several times. It worked like that a few more times, and then progressed to the point that I had to push in on the key as well as turn it to start the tractor (on this model, pushing in the key activates some kind of heating feature).
The last time I used the tractor, I had to push and jiggle the key for several minutes to get it to work. When I turn the key one click to the on position, the dash lights come right on and the usual constant clicking sound happens, but then when I turn the key to the start position, everything goes dead (until it's been sufficiently pushed and jiggled!).
Once it works, it fires up instantly and runs great. Does this sound like I need a new ignition switch, or is there another problem I'm not considering?
Thanks!
/ John Deere 4105 starting problem (?ignition switch?) #3
Did you determine the problem? Mine is doing
Same thing but I have linked it to possibly being PTO safety switch not telling the computer that the PTO is off.
/ John Deere 4105 starting problem (?ignition switch?) #4
In my situation I have to work the PTO knob in and out until it will let the tractor start. The PTO is engaging and disengaging like it should. It's just like the Saftey switch is not being told it is disengaged. Weird thing is it only does this every now and then.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
UNUSED KUBOTA BT3004-24" PIN ON EXCAVATOR BUCKET (A62130)
UNUSED KUBOTA...
Electric Concrete Mixer (A61166)
Electric Concrete...
(INOP) KUBOTA M9000 TRACTOR (A62130)
(INOP) KUBOTA...
GIYI GY-PG72C 72" HYD GRAPPLE BUCKET (A62130)
GIYI GY-PG72C 72"...
