Quick Hitches Land Pride Quick Hitch
/ Land Pride Quick Hitch #1
taborekle
Gold Member
St. Marys County, Md.
Kobuta B2920
So after reading all the Quick Hitch threads and weighing the pro's and con's of getting the very cheap Harbor Freight QH, I decided to bite the bullet and go with the Land Pride QH. This is offered through my local tractor dealer, who has recently sold me my tractor, 2 Land Pride implements and a Woods implement.
I'm not terribly handy, and I wanted something that I knew was going to work right out of the box. No drilling, welding or bending required. Since 2 of my 3 implements (the RTR0550 tiller and a blade) were LP and were stated QH compatible, and since the Woods cutter was also branded QH compatible, I felt that this was my best shot at minimum work and maximum smiles.
Got a chance to mount it yesterday and after a little adjustments to the top hook, found that I could backup to my tiller, grab it with all 3 hooks, lift it and without getting off the seat, lock it in place.
I did have to get off the seat for the PTO hookup, but I found that the LP QH was not terribly in my way, and it was relatively easy to hook up. No more difficult then usual for the PTO attachment.
When I purchased the LP QH, my tractor sales man and I chatted and I brought up the HF and he admitted that he has seen a few of them come in on the back of tractors. He did not comment on wether they worked or not, but he felt that their quality was 'not there'. About what you would expect him to say.
I'm satisfied with my LP QH and would recommend it. I paid about $350 for it.
/ Land Pride Quick Hitch #2
Good to hear you are happy with your QH. Land Pride does make quality products. I've never heard anything negative said about them. I don't mind paying a little more for quality.
/ Land Pride Quick Hitch #3
You bought what I believe to be the best QH made..
You're gonna' love it!
/ Land Pride Quick Hitch #4
Out here in OrEEgone, Land Pride is King. The stuff holds up under demanding conditions. I never mind paying a little extra for quality but I hesitate to pay a lot for it. HF at least provides me 30 minutes of entertainment when I go to town, and I usually bring something home. But having said that, I drool around LP equipment. That same QH here is priced at $499. Go figure.
/ Land Pride Quick Hitch #5
gentlemen,
i don't know which is more of a beast, the and land pride qh-15 series on the back of the new bx2360, or the 2360 itself. it came on the tractor as part of a negoiation trading in my sickly bx1850.
i believe i made a good choice and am searching for a landscape rake, rear blade and tiller.
regards, shrekbelly
/ Land Pride Quick Hitch #6
I can tell you that I have yet to find another QH brand that can beat the Land Pride in build and features. I wouldn't be without mine! :p
Troy
/ Land Pride Quick Hitch #7
Where is the bst place to buy one? What can I expect to pay for a Cat 1 QH?
/ Land Pride Quick Hitch #8
I bought mine with my tractor at the Dealer. It cost me $300. They aren't cheap but you won't ever have to worry about it being the weak link either. There are cheaper ones out there that will work if price is a major factor. I have seen the "off brand" ones for $100 to $179 in TSC and the like and on EBAY. Any QH is better than NO QH :p
Troy
/ Land Pride Quick Hitch #9
I know this is an old thread, but rather than start a new one, I figured I'd ask here.
I've gotten fairly decent at hooking up my implements, but I can safely say that I don't think I've ever backed up to an implement, got off the seat, and hooked it up without messing with at least one lever to get the lineup correct. Ever since finding out about quick hitches, I've thought about one every time I've hooked up an implement. (Note: this is yet another attachment that I didn't know I needed, or even existed, until I read about it here on TBN) :laughing:
I have a few very heavy implements that I can't really "push around" if I'm a little bit off on my approach, and I think I'd really like quick hitch for these times.
The main reason I'm thinking about purchasing one, is because over time, I've found myself not using the right implement for the job, simply because I knew it was a hassle to unhook/hook up another implement. I think with the QH, I would be a lot more apt to change out implements when needed.
I know 3 of my implements are QH compatible, and I know 2 implements that aren't, but I don't know about the others. When something isn't QH compatible, what part typically isn't the "compatible" part? I would assume that all lower link parts are the same, since it's a standard width. So is it that the top link is in the wrong spot?
With the adjustable top link on the Land Pride unit, do you guys that have them find that there aren't many implements you can't make work?
Are you happy with the LP unit now that you've had it a while?
/ Land Pride Quick Hitch #10
It's rare to find the lower pins are wrong width. If there's a problem down there it will be structural supports built into the attachment that might be in the way of the hooks coming at the pins from the bottom. I've got a Rhino 6ft brush cutter that has that problem.
Usually it's the top link. Most issues there are the same as above. There will be something in the way that prohibits the hook from approaching the top pin from the bottom. Next issue would be the top pin is the wrong height.
These issues can be overcome with a little thought and labor. The payoff is worth it if you have several attachments.
It's very common for me to have 2 or more 3pt attachments on my tractor in a day of work. I never dread the hook/unhook. I added a QH to my tractor shortly after I bought it. Little over a year later and the QH has not been removed once.
I don't mind paying for a quality product. I might buy cheap Beer, but I avoid cheap tractor accessories. :drink:
/ Land Pride Quick Hitch #11
Its mostly the top hook that is off. Having my LP QH now for a year I would not trade it in. The LP QH is top hook adjustable.
/ Land Pride Quick Hitch #12
I live in western Kansas, but my job is based out of central Kansas ( Salina, Ks.) I have a part time job also that is located in Salina, next to Land Pride's Product Development division. On occasion we have come running out of the shop to what sounds like some 16 year old doing a demo derby in the parking lot. What it ends up being is Land Pride testing out a new piece of equipment. I have seen them take new a zero turn mower and run it into a concrete retaining wall not once, but numerous times. There is always one of their guys abusing something to test it's strength. Their equipment is built tough and tested tough. The other day we asked one of their workers what a piece of equipment was and he replied a 14ft rotary mower. It was a monster. IF I changed implements very often I no doubt would buy the Land Pride.
/ Land Pride Quick Hitch #13
Piston, on my Gannon box blade (which is an old one), the structural support tube for the top link connection sticks out about 1/16th of an inch too far, which keeps the hook on my quick hitch from being able to engage the top link pin. I've actually thought about grinding 1/16th or so off the back side of the hook on my quick hitch so it will work with the Gannon.
/ Land Pride Quick Hitch #15
Lazy chit, I use for health reasons. I can't believe people can't spell the name of the Tractor they own.
/ Land Pride Quick Hitch #16
I can't believe people are to lazy to hook up to their implements.
I can't believe people are so lazy they want to ride a tractor instead of walk behind a mule all day.
Bruce
/ Land Pride Quick Hitch #17
I have a Land Pride quick hitch, which I bought after having the fixed John Deere quick hitch. Both are great-I'll never be without one again.
I'm getting ready to buy another JD fixed or adjustable quick hitch for my JD tractor, and move the Land Pride quick hitch to my 1953 Ford NAA.
Call me lazy, but I call it a time saver. I can move implements around without having to get off the tractor or hook up quickly to do a project. I've had all the practice hooking up implements without a quick hitch I needed when I was younger. Gotta work smarter these days.
/ Land Pride Quick Hitch #18
Maybe a Mahendra is a chicken tractor. :)
But I still don't know what's a Kabota or Kuboda.
Bruce
/ Land Pride Quick Hitch #19
double post....
/ Land Pride Quick Hitch #20
I don't mind paying for a quality product either... including beer! So much so, that I stock up on Octoberfest before it's gone. I got every one of the last 12 packs from my local store, would have bought more to last through the winter but they ran out. :laughing:
I didn't think of the "clearance issue" with not having enough space for the top hook to approach the pin. I'll have to look at a few of my implements.
I called both Brown Manufacturing, and Shaver, regarding my rotary cutter and stump grinder, and they both said that it won't work with a QH. I'm hoping with a fabrication I can get them to fit, the stumpgrinder is a beast to move around and for some reason one of the most difficult to get lined up.
That's good to know. I do really like my LP equipment, I'm not die hard to it, as I don't mind other manufacturers, it's just that my most used equipment has been LP as those were the ones that I've found on the used market, when I was looking. I'm starting to become a little "partial" to LP equipment though, after being so happy with it in the past :D
Pappy,
I think my box blade has a similar design. Anyone have a LP 35 series box blade with a quick hitch? They did say it would fit though so I think I'd be okay. I wouldn't worry much about grinding a 1/16th off, seems like it should be fine?
People who are lazy, don't use tractors, heavy equipment, and they're own tools to do they jobs they need/want to do. They sit in front of a TV watching games/movies or playing video games. Gitchyour head outa yourass...
Bruce
X2 :D
Here are some of the "questionable" implements that I'm hoping I can get to work.
View attachment 353849 View attachment 353850
View attachment 353852 View attachment 353853
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
AUTOMATIC TRANSMISSION / TRANSFER CASE (A68842)
AUTOMATIC...
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
