Giving up on 2750d blower
/ Giving up on 2750d blower #1
rbarker
Massachusetts
BX 25
I've just spent the last couple of hours removing the blower and installing the loader on my BX 25 in the middle of a foot and a half of snow in the dark at 5 degrees. I was using the blower on the light powdery snow when the fan stopped turning. The augers are fine. The shear bolt is broken but all the pieces were still in place. But the fan is completely jammed and will not turn even though I disabled the mid pto. I can't see anything stuck in there and I know I didn't hit anything. Really frustrating since the storm is only half over and the worst is still to come. I think this is the final straw for this blower. It just keeps letting me down and with a blower when you need it you need it now. Luckily the loader never fails.
Sent from my iPad using TractorByNet
/ Giving up on 2750d blower #2
Warm up, get a hot drink, and wait until day light. You will be able to see better then. Meanwhile you've got the loader to bail you out.
/ Giving up on 2750d blower #3
Just finished blowing 400' gravel drive on my B2620 with a 2781 front blower. No problems....got to remember to lube the chain before the next storm.......
Hopefully your fan is only jammed with a stick or large stone and you can free it up.
Just finished blowing 400' gravel drive on my B2620 with a 2781 front blower. No problems....got to remember to lube the chain before the next storm....... Hopefully your fan is only jammed with a stick or large stone and you can free it up.
I hope so too, but I couldn't see anything. It's just too dang cold to futz around with it right now. All in all not a good couple of days for the kubota. Took way too long to get the loader on last night due to problems lining up the pins. Turns out there was snow on the pivot points that packed down and made about a quarter of an inch of ice which was just enough to prevent the pins from lining up. I would never have thought that possible until last night. Damaged the cab with the left loader strut because I couldn't see what the heck I was doing. Couldn't get the block heater plugged in last night (frozen?) so it really didn't want to start this morning. Took several tries. Then had some fuel gelling issues which kept stalling the tractor for about 20 minutes even though the fuel was fresh that morning and treated with a double amount of power service. I usually use the 911 product and I'm going to get some of that to add as well. Finally got the driveway clear just in time to rush off to work. Now I have several repairs to make hopefully before the next storm.
/ Giving up on 2750d blower #5
Wow that is rough. My blower is flawless- knock on wood
/ Giving up on 2750d blower #6
You'll get it! Things get frustrating fast in real cold weather. I sometimes use a hand held propane torch with heavy gloves to get things where I want them, like pins, frozen quick connects, etc. The heat tends to even the playing field at well below zero.
Try some Fluid Film on your chain drive.
/ Giving up on 2750d blower #7
Good luck with it....like I said I hope it is a simple fix. Looks like tonight is going to be -20 or so, might not be a good night to work on your rig!
/ Giving up on 2750d blower #8
good luck and try to stay positive
this weather this year has been a b@#!
global warming sucks
/ Giving up on 2750d blower #9
Bob, when my new BX25 and BX2750D were going out to blow snow for the very first time I started off at maybe 2000 rpm. I went about 15 feet and sheared a fan bolt. So I changed it and in doing so I let the old shank drop into the bottom of the shroud. Well, I got back on the tractor, started her up, and engaged the pto. Thunk. The fan stopped dead; it never got spinning. WTF? And now the fan was locked and would not turn. I know how frustrated you can feel about your 2750D. After looking around a bit, I found the old shank jammed between the end of a fan blade and the shroud. So I blew a total of 15 feet and was on my third bolt! In the end I sheared 6 fan bolts that first winter.
This is an awesome snow removal tool. It will move tons of snow; I blew for 2 hours today. You just need to learn its idiosyncrasies and hang in there. A couple of things I did that helped me was to start running at WOT and I made some new skids which actually extend beyond the cutting edge. Since doing these 2 things I have reduced my fan bolt breakage to maybe one a year (1 auger bolt so far this year).
So don't give up on that blower!
Dean
Bob, when my new BX25 and BX2750D were going out to blow snow for the very first time I started off at maybe 2000 rpm. I went about 15 feet and sheared a fan bolt. So I changed it and in doing so I let the old shank drop into the bottom of the shroud. Well, I got back on the tractor, started her up, and engaged the pto. Thunk. The fan stopped dead; it never got spinning. WTF? And now the fan was locked and would not turn. I know how frustrated you can feel about your 2750D. After looking around a bit, I found the old shank jammed between the end of a fan blade and the shroud. So I blew a total of 15 feet and was on my third bolt! In the end I sheared 6 fan bolts that first winter. This is an awesome snow removal tool. It will move tons of snow; I blew for 2 hours today. You just need to learn its idiosyncrasies and hang in there. A couple of things I did that helped me was to start running at WOT and I made some new skids which actually extend beyond the cutting edge. Since doing these 2 things I have reduced my fan bolt breakage to maybe one a year (1 auger bolt so far this year). So don't give up on that blower! <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=353104"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=353103"/> Dean
Well Dean you are pretty much right on the money, except it's not a piece of the shear bolt. In fact, I'm not too sure what it is, maybe a piece of rock? It's almost the same color as the housing so it's real hard to see. Looks like it's about an eighth inch thick and man is it wedged in there. It's visible from both sides so there is no obvious direction to turn it. I pounded pretty good on the blades trying to get them to turn but no dice. Any suggestions? Here's a picture of what I'm talking about.
As for the other stuff, well I've got the Diesel 911 on board and I managed to get the block heater plugged in so if I need the tractor I should be okay. I do always blow at or near wot and my driveway is paved so no real gravel issues but I think your guide feet are a great idea and I'll try to adopt them before reinstalling the blower. I used a back blade and loader for 10 years on my old BX so I just panicked and went back to what I know. When it works, though it surely will throw snow.
Thanks all for the kind wishes!
/ Giving up on 2750d blower #11
The first thing I'd do is melt that snow away to see what you're dealing with. You can't figure a course of action until you know what it is. You can use hot water or a torch maybe. If it's a rock maybe you can break it up. But you need to see what it is to figure out how to deal with it.
Dean
/ Giving up on 2750d blower #12
Not to dis anyone, but this is one of the reasons I went with a rear-mounted snowblower. I know it's a pain to look back while using it. But the components seem to be a little heavier-duty and the pto shaft is stouter and shorter as well. Plus you get to keep the use of your bucket.
Forgot to mention: cheaper too.
/ Giving up on 2750d blower #13
I agree. The FEL / rear blower combination has served me well. It was 6 degrees this morning and I envy all you guys with cabs.
The front blowers I have looked at are made with tighter clearances than my Farm King which is probably why they throw snow so far. Mine is very sloppy and will hardly throw snow 15' at WOT but, I've had it three seasons and not broken a shear pin yet.
/ Giving up on 2750d blower #14
get a hand torch and heat away the snow/ice. Looks like a rock has wedged tight in there.
/ Giving up on 2750d blower #15
I agree with Dean. Melt the snow away with some hot water. I doubt it will take much to clear it away, then you can see what you're doing.
I used my BX2750D for years before I sold it, and I never once broke a shear pin. It's a great snowblower, so don't give up on it!
/ Giving up on 2750d blower #16
Yeah, melt it then move it. What comes to mind is not beating on the blades, but breaking up what's jamming them. I think you could use an air driven chisel to break the jam quickly then back to plowing! JMHO. :thumbsup:
Ahhhh! An excuse to go buy a tool I don't already have! I like it! It's supposed to warm up in a couple of days so I'll melt it out then but I'm pretty sure it's a rock the more I think about it. I like the idea of going at the object and not the blades. I'll give that a try.
/ Giving up on 2750d blower #18
Yeah, now you're thinking! An air driven chisel is not an expensive item, and with a few good chisels you can get a lot of impact right where you want it. Think of it this way, whatever got jammed is now wedged in place, your objective is to unwedge the object, not your fan. If you can pulverize the object the fan spins, and then you are back in biz.:dance1:
I got a short handled air impact tool and a kit of bits/chisels for next to nothing at H. Depot. It's saved the bacon on more than one project.
/ Giving up on 2750d blower #19
Shear pins break, get used to it. Lately here it has been -40F and shear pins break a lot more often. Buy a punch slightly smaller than the shear pin (the one I bought cost $1) . rotate the (of course you have shut the tractor off) auger while tapping the punch through the hole with a small hammer, ( you will have to move the auger left to right, forward and backward, you will feel when the punch fits into the hole, if it does not, rotate the pto shaft or fan 1/2 of a turn) until things line up. Then put in the new shear bolt you bought from your dealer. Tighten somewhat tight. Similar situation when you eventually shear the pin for your fan.
Thanks for the suggestions, but in this case the fan is jammed and won't rotate so I can't change the shear bolt. I have a punch and a full supply of replacement bolts ready to go if I can free the fan. I realize the pins are there to protect the drive train from damage so they serve a valuable purpose but it doesn't help when you are looking at a foot and a half of snow that needs to be moved.
Unverferth 235 Seed Tender Wagon (A64047)
Unverferth 235...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2013 WESTERN STAR  4900 SB (A63569)
2013 WESTERN STAR...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59910)
2011 GREAT DANE...
