Box Scraper Box Blade use question..
/ Box Blade use question.. #1
Wa11banger
Gold Member
Huntsville Al
Foton FT404 w/Koyker 160 FEL and a Dig-It Towable Backhoe
Hello fellow TBN members and Happy New Year.
Again with the ignorant questions so I apologize in advance
I have a Foton 404 tractor.. It has the wheels turned out so it is 6.5 feet across outer edge to outer edge.. After reading a ton of posts on Box Blades here I took the advice and got a 7' box blade so I could cover my wheel tracks while working with the tool. Santa was good and got me a brand new one although not the heaviest in the line up it comes in at almost 700# ;).
Then I was reading around and several other members were talking about how their BB can stop their tractors in their tracks. One member with a 50Hp tractor stated his 6' BB can stop his in place with the rippers down. Now mine is only 40Hp, it is 4wd, and with those posts I am wondering if I have over sized my purchase and should have stuck with a smaller BB at risk of tire marks in my work area. so here are a couple of questions.
Is there a way I can control the digging depth with the rippers down. I think I understand that you set the box blade for the grade depth you need or desire and it should stay there? but do the rippers draw it down naturally due to thier angle
Is there a trick or lesson that applies to the angle of the blade using the top link that can help a newbie like me control the problem? Angle back a little etc? or does it just come from practice?
Lastly, every video I have seen shows the tool being pulled for use. My BB has a blade on the back as well can you go backwards and push? If so is there any particular gotcha moments to watch out for to keep me from damaging it that way?
Thanks all.
/ Box Blade use question.. #2
To start with your last first...a 3PH is not really meant to push backwards...light loads are OK but the arms can be bent or worse...
as for the scarifiers stopping the tractor...it is usually a case of a big root or big rock... remember a tractor is not a bulldozer...
/ Box Blade use question.. #3
I think that that box blade is going to be too big for tractor. If it does pull it, it will take every horse you got. My 33hp 4wd tractor with loaded tires and a FEL is about all the tractor wants, especially if full and pulling up any incline.
/ Box Blade use question.. #4
Thanks all.
My first question would be what does the 404 weigh, if it is heavy like my chinese tractor - 5400#s before adding the loader or the back blade and if like most chinese tractors the 40 hp is @the pto and rated @12 hours of continuous duty -then I think it will pull it fine.
I run my Gannon 76 inch box -1000+#s on my Rhino and my ford 3000 and it will pull it on both machines although if I get to aggressive the ford will spin and require lifting the box blade if it gets to full and the drag gets to high. I would try it ...
/ Box Blade use question.. #5
Ripper/scarifiers depth is controlled by the operator running the controls. If you start spinning lift the 3PH a little, pulling easy lower the 3PH a little. Blade narrower than the tires would potentially cause problems if you are trying to cut a ditch or create a bank of some sort.
Being an odd ball I have a 5 footer than I used on my BX1850 and now on my Branson 2400H. Yes sunk deep it will spin but I have yet to fail on finishing a job by taking a couple more passes.
/ Box Blade use question.. #6
After reading a ton of posts on Box Blades I took the advice and got a 7' box blade; it comes in at almost 700# ;).
Lastly, every video I have seen shows the tool being pulled for use. My BB has a blade on the back. Can you go backwards and push?
For serious Box Blade use T-B-N consensus plumps for 150 pounds (+/-) of weight for every foot of Box Blade width. So 700 pounds is not too heavy and comfortably within the capability of a 40-hp, reasonably heavy tractor with four wheel drive, unless you have beastly soil. It is easiest to peel with a Box Blade when the soil is a little moist, hardest when brick dry, you will not have tire traction in mud or soil conditions resembling mud.
Longer Top Link = more bite from Box Blade, thicker peel.
Shorter Top Link = less bite because blade will be more vertical/scraping rather than peeling. You want shorter Top Link to smooth as you approach job completion.
TRACTORS ARE DESIGNED TO PULL. You can reverse - push, gently, LOOSE dirt, IF YOU HAVE RIGID THREE POINT STABILIZERS supporting two Lower Links of Three Point Hitch. (See picture)
If you have "Turnbuckle" "check chains" you will bend them if you push. (Ask me how I know.)
It takes quite a few operating hours to master Box Blade technique.
LINK:
http://www.tractorbynet.com/forums/attachments/285687-kubota-b3300su-rollover-box-blade.html
Stayed in the CCC cabins in Monte Sano State Park during early December. Nice. Quiet.
/ Box Blade use question.. #7
That may have been one of my posts you mentioned about the Gannon 6' blade stopping the tractor. One thing that will make a difference is the type of soil you have. I have heavy, black, gummy clay. It will definitely bog the tractor down if the box blade and rippers dig in too much.
In loose sandy loam like Jeff has it would not bog down as much, as it takes less force to pull through it.
I looked up your tractor on TractorData.com and it shows it to have 40hp and weigh approx 4,300 pounds. I think your tractor is right on the edge of being ok for that blade, but maybe not. If you don't have the rear tires filled, you should get them filled to help with traction. If you find your tractor a little too light and/or underpowered, just take smaller bites. If your tractor has draft control on the 3point hitch, fiddle with it some to limit the bite.
/ Box Blade use question.. #8
Oh, and you would not want to be digging or blading with much force going backwards and using the back edge of the blade. It puts too much stress on the 3 point hitch lower arms. That back edge is intended for light duty work such as leveling loose dirt piled up.
All thanks for your replies all good info.
Jeff, thanks for the tip about filled tires, I do not yet but will soon. I have a FEL installed so hopefully that helps some as well. I do have rigid style pin adjust links like you show in your pics but they are on the outside instead of the inside and the go back to the axle mounts on each side. Great advice on the tilt to thank you
Pappy, I think it was one of your posts that I was quoting. I do have draft control but am still struggling with how to use it. Hopefully with practice I will figure that part out. I look forward to spending more time in the seat and getting some experience with it soon
/ Box Blade use question.. #10
You just adjust the depth of the scarifiers to fit the soil conditions that you have. Or maybe take out a couple of them. As noted, the tilt also affects this.
Does you tractor have a "draft" control? If so, using it (and the proper toplink attachment point) should cause the 3pt to lift when the pull gets too hard. Sort of automatically adjusting your depth to the load.
/ Box Blade use question.. #11
Are you sure about that?
In my experience that's exactly backwards.
I have a hydraulic toplink on mine, and when I shorten it (tipping the blade forward) it cuts deeper, when I lengthen it (tipping the blade backwards) it goes from digging to dragging/smoothing.
I have a 5 footer behind a JD750 (18 hp) with no ballast/weights/loaded tires. While I CAN stop it if I get too aggressive with the forward tilt, it's easily overcome by either lifting a bit or reducing the cut angle a bit.
My major use for it is maintaining a gravel driveway. As long as it has rained in the previous week or so, I can drop the scarifiers all the way down, tilt the box forward enough to get it to start cutting and with 2 or 3 passes (in 1st or 2nd and 4WD) tear 4-6 inches off the top with eliminates most of the potholes. Then I lift the scarifiers, tilt the box back to grade mode and drag everything out nice and smooth.
/ Box Blade use question.. #12
Box blading is an art .. The more of it you do the better u get ... You do not have too much blade for your tractor as stated lift up if needed
I have draft control but am having trouble understanding how to use it.. It is another contol lever right next to and exactly like my 3ph control lever. But what is confusing is its use.. It seems when I have the draft control set roughly 3/4 to all the way up I can control the implement (raise/lower)
If I have it 3/4 or less it seems I can no longer raise or lower the implement.. really puzzling me right now
/ Box Blade use question.. #15
Thanks for the tip about filled tires, I do not yet but will soon. I have a FEL installed so hopefully that helps some as well.
If you are going to be doing any garden or crop work, think twice before loading your tires. Soil compaction is something to always consider and avoid. Stay as light as possible while getting your job done.
Before four wheel drive became common in the mid-1960's, loading tires improved traction on two wheel drive tractors, which were mostly in the 3,000-4,000 pound weight range. Today, with four wheel drive, I would rather wait for very-good to perfect soil moisture for traction rather than always having loaded tires.
I do not have loaded tires on my 1,900 pound Kubota B3300SU and I pull a 560 pound Rollover Box Blade without difficulty, through rock free, sandy-loam.
With you rigid stabilizers supporting the Lower Links you can push SOME, LOOSE dirt, gingerly. You cannot compensate for the fact that tractors are fundamentally designed to PULL.
LINK:
http://www.tractorbynet.com/forums/owning-operating/258630-soil-compaction.html
Jeff thanks for the link to the soil compaction thread, I think I will keep the tires how they are with that info. Good read and yes once the area is clear, AG will be the primary use of the tractor. I will have trees, roots, and the like to clear first then level and prep for growing vegetable with only a few row crop needs.. Copy that what you all have said about going backwards.. I am pretty sure I am just going to leave that part alone. I just thought it was odd to have a blade there if it couldn't.. So best advise for me would be don't ;)
/ Box Blade use question.. #17
Rick, what I use the back edge of the box blade for is just leveling loose piles of dirt. For example, if I dig up a cedar tree, I'll have piles of dirt laying around. I'll use the box blade to fill that dirt back into the hole. Sometimes it's convenient to back up to a small pile of dirt and push it backwards into the hole. Doing that won't damage anything.
Just dont try to do any digging or heavy duty dirt moving when pushing with the back side of the box blade, and you'll be ok.
/ Box Blade use question.. #18
If you are going to be doing any garden or crop work, think twice before loading your tires. Soil compaction is something to always be considered and avoided. Stay as light as possible while getting your job done. Before four wheel drive became common in the mid-1960's, loading tires improved traction on two wheel drive tractors, which were mostly in the 3,000-4,000 pound weight range. Today, with four wheel drive, I would rather wait for very-good to perfect soil moisture for traction rather than always having loaded tires. I do not have loaded tires on my 1,900 pound Kubota B3300SU and I pull a 560 pound Rollover Box Blade without difficulty, through rock free, sandy-loam. With you rigid stabilizers supporting the Lower Links you can push SOME, LOOSE dirt, gingerly. You cannot compensate for the fact that tractors are fundamentally designed to PULL. LINK: http://www.tractorbynet.com/forums/owning-operating/258630-soil-compaction.html
Personally I wouldn't have a tractor with out loaded rears .. But that's me ... You add ballast every time u hook up your 560 lb blade
/ Box Blade use question.. #19
I had one with out loaded tires and it was a useless as t!ts on a bull. The one I have now has them loaded, but I don't do any crop work either.
/ Box Blade use question.. #20
Rick, I've been reading your box blade discussion with interest because after years of using a rear blade, I just got a box blade. You haven't mentioned whether your box blade has a hinged rear blade or not. There was some advice given on how to angle the box for deeper or shallower cutting, and others took exception to it. I wonder if the difference has to do with whether the rear blade is hinged or not. Seems like that might affect the action of the blade. There must be some enhanced benefit to the hinged rear blade, because the more basic models tend to have a fixed rear blade, while the hinged blade is an option, or available with a heavier blade.
One thing I've noticed, when pushing dirt going backwards, is that to keep the blade from catching and digging in, it can be a good idea to keep the blade raised up a little bit instead of leaving it in "float" with the lever all the way down.
On the issue of whether to fill your rear tires or not, that's everyone's personal decision, and I suppose that soil compaction when farming is a consideration. In that case, adding removable wheel weights is an option. For just about every other purose, filling the rear tires for ballast is a good idea. When doing front end loader work you need a counter ballast of some kind, and filled tires help in addition to a heavy attachment on the rear. Filled tires or wheel weights also help for stability on side slopes, by lowering the tractor's center of gravity.
