Oil & Fuel Handling diesel
/ Handling diesel #1
JonKioti
Newfoundland, Canada
CK-20S HST
Hi everyone,
Has anyone found a better way to get diesel out of the container and into the tractor? The bendy plastic nozzles have developed splits in them, and I can't seem to find the correct replacements like you used to be able to get. I tried a third party one, but that leaked. :(
I'd use a funnel but it's hard to see how much fuel is in the tank when doing so. If anyone has found a better solution (hand pump that doesn't drip?), please let me know.
Thanks,
Jon
/ Handling diesel #2
I use a hard plastic funnel w/ long spout. Works great. NO mess :cool2: As for seeing, I only use 5 gal fuel cans and top off when my fuel gauge says approx 1/3 tank left. I never worry about spillage, it doesn't flow over ever....I can just see the top of the fuel in my tank and gauge registers ALMOST full. Worth piece of mind.
/ Handling diesel #3
Our state Governor about 6 to 8 years ago passed a law that outlawed the sale of any gas/diesel cans that didn't have that plunger type fill spouts. No more externally vented cans. What a pia. To hold 5 gals over the loader for 5 mins while an internal vent is burbing the container gets old fast. Enter the TUFF JUG. This dumps 5 gals in a little over 38 seconds. You don't have to hold it on the rim of the tank neck just steady the jug on the fill neck till empty (38 seconds). And as far as overfilling, that does not exist with the tuff jug. NO SPILLAGE when full it stops dumping fuel. Just lift off the tank neck and a plunger shuts off flow. Pricey but well worth my money.
/ Handling diesel #6
I had the same problem until I found a used 300 gal tank on a stand with a gas station type hose/nozzle....life is much better now:D
/ Handling diesel #7
I have two 50 GL tanks with hand pumps. One gas and one diesel. They are on pallet skids. When empty just load min the PU with the FEL forks and go fill at the pump then unload at home. They are a max lift for my BX25. Fuel never gets contaminated and pumps through a 10 micron water absorbing spin on filter. Each one is a $350 investment, sure worth it.
Ron
/ Handling diesel #9
I use a couple old plastic 5-gal jugs that predate current laws. They have that bendy corrugated pipe on the nozzle, which could come off in the tractor's fuel tank. I've been meaning to drive in a sheet metal screw to prevent that possibility but I'm always in a hurry when it occurs to me.
In any event, the politicians that inflicted the current generation of tanks and nozzles on us should be punished, preferably by forced labor in a fuel yard for a period equal to their time in office.
/ Handling diesel #10
Set jug on fender, take useless nozzle off it, take this siphon hose and place little ball check valve in jug, other end in tractor tank, jiggle hose up and down a few times to prime, walk away, check oil, etc.., empties 5 gallons in a minute or two
Google: Safety Siphon SafetySiphon__44696.1313616205.1280.1280.jpg.
/ Handling diesel #12
Lifting and holding up a 5 gallon can of fuel higher than the fuel tank gets old very quickly so I put the full can in the FEL and lift until it is higher than the fuel tank. Then I use a jiggle siphon to get the flow going and then lift the FEL higher to get a faster flow and go and watch the grass grow. No lifting, no mess, time to go and do something else.
/ Handling diesel #14
pallet + white plastic drum + fill-rite electric 12v pump = heaven... (cost around 300$ worth of diesel to fill the drum)
bought the entry level fill-rite 12v pump and did my own plumbing, bought a manual nozzle with 16 feet 3/4" hose.
filling the tractor (DK45SE) now take less than a minute... instead of using my tractor's battery I just use an old ATV battery.
/ Handling diesel #15
There was a LOOONG session on this a while back. Go on line and look up EZ Pour to buy yourself a new flexible nozzle. Your TSC may have some. You can also find new vents or buy them, drill 1/2" holes and put vents into your can/plastic.
I personally use a kerosene syphon that I bought at TSC about 10 years ago. I use it until the 5 gallon container is down enough so that I can lift it and hold it. Just sit the container a little higher or on same level as the fill hole to your tank.
Ralph
/ Handling diesel #16
/ Handling diesel #17
Thanks to all who mentioned and posted those web sites for the easy pour and poly vent. I had to fill my tractor after plowing seven inches that fell yesterday. After some more choice words for those stupid safety cans, I ordered several for all my fuel cans. I wish they would just sell the old style and put a warning on them saying if you are stupid, you may blow yourself up. Thanks again to all.
/ Handling diesel
Well, thanks everyone for the good information. I don't use enough to warrant a stand alone tank, as much as the convenience of it would be nice. I'll see if the EZ Pour will fit my cans and get some ordered. I'm ok to hoist the can for a while yet, I hope.
As a thank you, attached is a picture of a part of the lane I clear, taken just before the amount of snow down was doubled a few times.
Cheers,
Jon
/ Handling diesel #19
Got tired of the jugs and the mess and decided to put this together. It's 55 Gallons of diesel and easy to load in the back of my pickup for a refill at the local diesel station.
/ Handling diesel #20
Amen, that's what I did for both gas and diesel. I have the steel tanks and rotary hand pumps I fill both 2-3 times a year. I recommend you get the 10 micron spin off filter with the water absorbing media. Easier to keep track to get the off road use tax rebate also. Also i dose both with fuel additives when filling.
Ron
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
2013 GMC (A62613)
2013 GMC (A62613)
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
International 806 Wheatland Tractor (A66285)
International 806...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
