B3030 blowing fuse for OPC
   / B3030 blowing fuse for OPC #1
Papoonick
Merritt island
Kubota B3030
I have a Kubota B3030. I live on 3 acres and wouldn't want to be without it. I bought the tractor new but if I had to do it over again I would have bought one that is a little bigger & more powerful. I have had it for 8 years and it has been very dependable. The minor issues I have had I have been able to take care of myself. Right now I am having an issue with blowing the 5 amp fuse for the OPC system. Both seat switches check out OK. I have removed the HST pedal switch and I think that is where my problem is. Does anyone know how to check the switch?
   / B3030 blowing fuse for OPC #2
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
   / B3030 blowing fuse for OPC #3
I had the same problem with my b2630, it wasn't the switch it is in the OPC..A new OPC is $100 plus dollars
so I just jumpered it at the switch and this cured it...I put a jumper on the wires at the plug of the switch
   / B3030 blowing fuse for OPC #4
I had a similar problem.
Problem was the neutral safety switch. Periodically the switch would short out to ground blowing the OPC fuse.
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
