Big Barn
Super Member
- Joined
- Aug 20, 2013
- Messages
- 7,047
- Location
- Victoria, B C
- Tractor
- More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
I'm a bit confused as well....
Did you unhook the mower from the 3 point linkage and drive the tractor away from the mower so the shaft separates in to two pieces?
Sometimes grease and clipping muck holds the shafts together so tight they will not slide together when you try to pull the coupling off the PTO shaft.
Once you get them to slide in the middle you find that was the problem rather than the PTO connection.
You should know what kind of shape your splines were in when you put the shaft on. Were they sloppy or burred?
ps
watch the direct pull son that pto shaft.. might damage the bearing carrier or snap ring / bearing ont he tractors pto stub shaft!
LeJohn added.
I would add to what you said to unbolt the comp. pto shaft from tractor then drive it out from the back side. When the u jount is turned all the way then there should be a clear shot to the shaft. This is after he does what you said, I think you might be right.
_________________________________________________________________________________________________________________________
pacerron added
It has happened to me with a Woods finish mower. I had to align the safety cover slots for the center zerk fitting and soak the square shaft with PB.
It still was a bear to get loose and really clean up. The same shaft stuck on me a couple times when I fully compressed it for storage and hung the loose end to the mower with the shaft cover safety chain.
Three problems with the shaft in 20 years isn't bad though. I always greased the center zerk but didn't think of the build up freezing the shaft till it happened.
With the OP having the shaft lock pin removed the coupling will either slide off the PTO or the shaft will separate.
If it really is stuck on the PTO end I would suggest trying vibration on the coupling with a little air hammer while the shaft is separated.
It is amazing what a little vibration will do to loosen stuck stuff.
pacerron,
this is a draw bar pulled mower that uses hydraulic lift to raise and lower. both tractor and mower are John Deere and the PTO shaft had a ring around it that would turn approximately 1/3 turn to release the PTO. when turing this ring it push down on a pin that released the pto shaft, after replacing the turn ring twice I just left it off and depressed the pin, that the ring had depressed when turned, with my thumb to release the pto. When I could not get the pto off by depressing the pin, I though the pin was the problem and took it out. Turns out the pin was not the problem. So in sumation, my pto shaft should slide right off, but will not budge.
