Ratchet Rake
/ Ratchet Rake #1
BlackDogTx
Waller, Texas
LS G3038H, Kawasaki Mule 3010 Trans Diesel
Well I got a Ratchet Rake last week, and finally got a day to install and play with it. It is awesome! I have been tearing out live oak scrub and vines all day long. Works like a champ! Knock it down, drag it out, and push it to a burn pile. I probably should have bought the next larger size (I bought the smallest one. Should have measured my bucket first), but it is doing the job. I should have bought one of these a year ago!! This thing is solid!
/ Ratchet Rake #2
Glad to hear you like it, I was looking at tooth bars and then watched the ratchet rake video, I may end up going that way also.
/ Ratchet Rake #3
If I may ask a question of you, what swayed you to the ratchet rake vs others (assuming you looked at others)? If nothing changes, I plan in ordering a pyranha blade Monday. Can you back drag smoothly with the ratchet rake?
/ Ratchet Rake
For my purposes, I could not be happier with it. I bought it mainly for clearing scrub. I noticed yesterday after using it, that this could be darned handy for smoothing out small areas of my pasture, and also to move/spread dirt and gravel (for larger applications I would definitely use a blade).
/ Ratchet Rake
I am not familiar with the Piranha products. I chose the RR as it is easy to install and remove, does the job for what I need on my place. As for back dragging, I was able to do that effectively, to ball up the brush and could even push it into a burnpile..
/ Ratchet Rake
Welcome to the RR Club. I keep mine mounted all summer. Just the thing for Briars & Buckthorn
I think I'll be leaving mine on most of the time. It's just that handy.
/ Ratchet Rake #8
I wonder of you could attatch it to a grapple. You could then pick the piles up as you go.
1209 (A64280)
1209 (A64280)
2005 John Deere 7420 (A60462)
2005 John Deere...
2019 CAT 259D (A60462)
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
2020 Deere 50G (A64119)
2020 Deere 50G...
