JD 3320 what is this switch for ?
/ JD 3320 what is this switch for ? #1
pokerboy57
John Deere 3320
I own a JD 3320 I've looked at this switch for 3 years and have no idea what function it has and more importantly under what conditions I would want to use it ? Any help would be appreciated. switch.jpg
/ JD 3320 what is this switch for ? #2
Total shot in the dark as the cab controls look a little different but is that your speed lock cruise control?
/ JD 3320 what is this switch for ? #3
/ JD 3320 what is this switch for ? #6
And this is why I don't gamble. Haha
thanks guys so it's a load match switch ..... SO when and why would I use it ?
/ JD 3320 what is this switch for ? #8
I use mine when using front bucket getting a deep heavy load, for dirt and stone and when climbing a hill mowing or moving stone or ag...kinda acts like a governor.
/ JD 3320 what is this switch for ? #9
Loadmatch will drop the transmission range down as soon as the engine begins to lug/stall under load... allows you to work at the speed you think you want to until the machine determines you picked the wrong one and "downshifts" to protect itself/keep you working.
Mine has only been turned off a handful of times... if you haven't had it "on", turn it on! Works great & keeps you from having to stop & shift constantly doing loader work & ground-engaging... also if you're transporting & hit any grade ("C" is anemic). I don't believe the PTO is influenced by it, except it keeps rpm's up when your mistaken selection range would start dragging the engine down.
/ JD 3320 what is this switch for ? #10
I keep mine on all the time too. Although in almost 3 years of year-round use on 30 acres of steep Kentucky hillside, I've yet to experience it "downshifting" the transmission range. Mine intervenes as a rpm versus speed manager only. See LoadMatch switch
//greg//
/ JD 3320 what is this switch for ? #11
I never use mine. I prefer to decide when to stop pushing instead of the computer telling me when it is too much.
/ JD 3320 what is this switch for ? #12
Same here on both the 4320 and 3720. Tried it on both tractors but prefer operating with it switched OFF for most work I do.
Decorative Bear Statue (A61569)
Decorative Bear...
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
2006 GMC C6500 Crew Cab Chipper Truck (A61568)
2006 GMC C6500...
