L3560 hstc LED install
/ L3560 hstc LED install #1
dale311
eastern ky
kubota L3560 hstc
20131224_134305.jpg20131224_134244.jpg20131224_113230.jpg20131219_125437.jpg Just got done today installing these 180 watt 17,000 lumen LED lights on my Christmas present.Icouldnt be any happier, these lights are crazy bright. The pictures don't really let you see just how bright they are.Purchased from amazon for $168.00 for the front and $103 for the rear lights. Very easy install i used the existing wires and switches and just tied into them..
/ L3560 hstc LED install #4
I just put two 27watt on the front of mine and thought they are quite bright...180 watt has to be like day-light!
/ L3560 hstc LED install #5
Very nice indeed.
27 watt is what is on the rear of my tractor and they are very bright indeed.And yes the 180 watt lights on the front may be overkill.Ijust hope in the summer they don't attract so many bugs that i won't be able to see how to drive.. lol
/ L3560 hstc LED install #7
Sure does look nice, I thought of replacing my work lights with LED's. I see your in Ky so it may not apply for you, which is good. I think here in the Northeast, in a snow storm that light would make it a whiteout for the operator and imposable to plow snow when snowing heavily. That is when I like to be out the most when the snow is coming down at night. I may be wrong, but I would think it would be like driving in fog with your high beams on. I would like to hear from others how they work in falling snow?
I guess you could just shut them off in that case and use the tractor headlights.
/ L3560 hstc LED install #8
Nice looking install, but that looks too low to be most effective. I'd like to mount lights over the cab, but then they would get torn off in the woods.
/ L3560 hstc LED install #9
Very nice, I bet those will give you more than enough light.
/ L3560 hstc LED install #10
waxman, i have a 2006 l4330hstc, i live in NH, no issues with led work lights on rear, however, i removed the front work lights and installed HID, they warm up ,no issues with snow building up etc, no issues with heavy blowing snow, and have had no issues on the rear leds, by the way nice job on the led marker lights !
/ L3560 hstc LED install #11
Ok sounds good, Thanks for that information, I will keep the LED's upgrade as an option. Thanks on the marker lights.
/ L3560 hstc LED install #12
Dale,
2 questions:
Do you have links to Amazon for the lights?
Did you have to rewire to a larger gauge wire to run the 180 watt lights?
/ L3560 hstc LED install #14
Thank you
/ L3560 hstc LED install #15
Hi Dale
Great set up! I just took delivery of my L3560 not too long ago and want to get the same light set up. I went online to the link you posted and the front light bar looks to be only 59.00 now I know you said it was like 160.00 I want to make sure I get the right one....Could the price have come down that much or is is a different light? If you could take a look and let me know I would appreciate it. Also do you think I could run the same large light off the back?
Thanks Again!
/ L3560 hstc LED install #16
BTR: the prices for LED lights have fallen, and if you buy from a reputable, US seller, or thru Amazon, which will provide consumer protection, you shouldn't have to worry. I have probably purchased 18-20 different lights for our own tractors and a friend's needs, and I don't think one of them has had any issues or failed to deliver good performance. Different sources, all cheap, all seemingly the same quality.
180W is a LOT of light for LEDs- you could probably thread a needle 25 feet in front of your tractor with that one. Just don't forget that it will be nominally 15 amps.
/ L3560 hstc LED install #17
Got a 32 curved led light bar, said amp was under 9. Wired it with a 15 amp fuse and no problems yet.
/ L3560 hstc LED install #18
Thanks Varmint I'm going to order a set before the winter hits us.
/ L3560 hstc LED install #19
Thanks Can you sen me the link on yours?
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A59912)
2012 INTERNATIONAL...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2257 (A64281)
2257 (A64281)
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
Caterpillar D9R Tractor Parts and Service Manuals (A63117)
Caterpillar D9R...
