Michigan 675 wheel loader project
/ Michigan 675 wheel loader project #1
Waldon52
Michigan , usa
John Deere
These photos show me on a Michigan 675 Wheel loader down by Grand Rapids , Mi. We drove down and spent 4 hours with the owner . He told us there are only three 675 loaders left in the world and only two of them still run. He also told us he bought and sold this machine three different times. We took plenty of pictures and I came home and built the model. That was a fun day with Russ. aaamich1.jpgaaamich2.jpgaaamich3.jpgaaamich4.jpgaaamich5.jpgaaamich6.jpgaaamich8.jpgaaamich9.jpg
/ Michigan 675 wheel loader project #3
WOW!!!
Whatever became of Michigan construction equipment?
/ Michigan 675 wheel loader project #5
Looks like those front tires where too soft or not enough rear ballast.
Walon thx for sharing. Did you get to operate the Michigan?
Great replica,
/ Michigan 675 wheel loader project #6
/ Michigan 675 wheel loader project #7
Thanks for the link, herringchoker.
That is a sad read - how insufficient investment & unfair competition wrecked a great American company. Way too common of a story now.
/ Michigan 675 wheel loader project #8
The tires were the biggest problem on the 675 because it was so heavy. I used to have a brochure on the Michigan C series loaders. What's interesting is that it listed the 675C model as the offering the biggest bite on wheels with buckets up to 36 cubic yards(for coal loading) but 24 yd was standard. 16 675's are listed as being built but that's a deceiving number. 2 675B's were bought back by Clark and rebuilt and sold as the C models. The prototype used 2 GM engines but had a lot of problems so they switched to 2 Cummins engines. I knew a guy that bought a 175B new and he said you couldn't hurt it! He also had a 75B and it wasn't as strong but he probably tried to do the same work with it as the 175. Michigan's are known as one of the best loaders ever made. Those old videos are fantastic!
As far as the welding, almost all of it designed for fillet welds so it doesn't need as much prep. I would also bet a lot of the steel is thicker to not only give rigidity but also give a good safety/abuse factor without needing to use 3" fillet welds. I would think there was some preheating required and the video showed them using a hand held sub-arc gun with the flux pouring over the weld. The safety police would have had a field day there, welding without gloves, no safety glasses, etc. I'd like to see how they build/form the huge buckets.
/ Michigan 675 wheel loader project #9
The tires were the biggest problem on the 675 because it was so heavy. I used to have a brochure on the Michigan C series loaders. What's interesting is that it listed the 675C model as the offering the biggest bite on wheels with buckets up to 36 cubic yards(for coal loading) but 24 yd was standard. 16 675's are listed as being built but that's a deceiving number. 2 675B's were bought back by Clark and rebuilt and sold as the C models. The prototype used 2 GM engines but had a lot of problems so they switched to 2 Cummins engines. I knew a guy that bought a 175B new and he said you couldn't hurt it! He also had a 75B and it wasn't as strong but he probably tried to do the same work with it as the 175. Michigan's are known as one of the best loaders ever made. Those old videos are fantastic! As far as the welding, almost all of it designed for fillet welds so it doesn't need as much prep. I would also bet a lot of the steel is thicker to not only give rigidity but also give a good safety/abuse factor without needing to use 3" fillet welds. I would think there was some preheating required and the video showed them using a hand held sub-arc gun with the flux pouring over the weld. The safety police would have had a field day there, welding without gloves, no safety glasses, etc. I'd like to see how they build/form the huge buckets.
Thank you for the explanation and reasoning behind the build design.
/ Michigan 675 wheel loader project #11
I believe the tires were specially made for the 675 and were the largest tires in the world at the time. They were 10' in diameter but didn't have a very long lifespan. I think better tires came along later. Looking at pictures of the 675, they had much wider tires than the the prototype. The 14 production machines were built between 1973 and 1976. I don't know when the 2 were bought back and rebuilt as C models. The International 580 came out in 1971 and was also a big loader. 18 yd's later upgraded to 22 yd. It used a single engine. It had a much longer production and evolved into the Haulpack 4000 with 24 yd bucket and lasted till 1996. The Letourneau L2350 is the biggest loader now and has a standard bucket of 53 yd's!
/ Michigan 675 wheel loader project #12
for what reason were the B models rebuilt as C ? the B series had twin Detroits and the C had Cummins ?
/ Michigan 675 wheel loader project #13
A must have been the prototype model(s) with Detroit engines, no cab, no roll bar. You would definitely need hearing protection with 24 cylinders of screaming Detroit behind you!;) The B models were the production models with Cummins engines. Possibly to renew interest in the 675 is why Clark bought a couple back and added similar refinements and improvements to them as the smaller C series loaders. I would think with all the development costs, the 675 was a big money loser for Clark, although from watching the old Clark videos, the 475 and smaller loaders were a great success. Some have speculated that the 675 may have been ahead of its time.
/ Michigan 675 wheel loader project #14
The company i work(ed) for till december 31th, used to put Detroit Diesels in wheel loaders too, on customer demand. (standard was a DAF engine, which is the predecessor of the Paccar MX)
Of the older 70's ones, only those with Daf engines are still around, the ones with Detroit are rare (for obvious reasons). The servicemen remember that when they had to do a 500hrs service at the quarry, even two 6-71's (in little 17 ton loaders) were deafening...
anyways, it seems they built a fair bit of 475s in a couple of years, if you believe the videos... But the 675 was double the size of the 675, maybe they overstepped that a little... in this size, all components have to be purpose built, so i understand their way of thinking that you cant offer as wide of a size spectrum as in the high sales volume class...
/ Michigan 675 wheel loader project #15
Don't know why more weren't sold, maybe customers didn't like the dual engines, limited tire life, too costly, etc.? 475's were quite popular though and lasted through the C series. I remember they had an optional turbo transmission with a 10,000 hour warranty. The Hough (IH) 580 wasn't much smaller but versions of it were around till 1996. I don't know how many they sold though. There's been other big loaders and machines built that also seemed to be ahead of their time that are now surpassed in size. The O&K RH300 is example. It is small compared to mining excavators today but when it was built was the biggest in the world by a good margin. Only 3 were built.
/ Michigan 675 wheel loader project #16
i guess the remote torque converters (a pump wheel at each engine, feeding a common turbine on the transmission input shaft) cant be that fuel efficient either...
Woods 1050 3Pt Backhoe (A66285)
Woods 1050 3Pt...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
