JD 650 Battery Polarity Issue
Status
Not open for further replies.
/ JD 650 Battery Polarity Issue #1
gurumanjohn
Member
Chatham, NY
JD 650
I have a JD 650 (1986) that I bough last Spring. Recently, the battery got weak and my neighbor and I went to charge it on a trickle charger. We discovered to our surprise that it required a positive ground connection. I checked the JD 650 manual and it says clearly that the tractor is a negative ground. What's going on?
/ JD 650 Battery Polarity Issue #2
I had a 750 (basically same machine) and it was negative ground.
Oaktree - Thanks, the manual specifically said it's a negative ground. The question is: why did someone change it to positive ground? Moreover, it doesn't appear that the wires were moved. They probably just turned the battery around. I'm wondering if it can be reversed to its original negative ground or is it too late for that?
/ JD 650 Battery Polarity Issue #4
Weird. One wouldn't think a "new" (1986) tractor would be positive ground, and the manual and others seem to confirm that. So, this has got me thinking: what happens if somebody puts battery in backwards? Nothing or is something else going on here? Not sure, but seems like the alternator and maybe the starter motor would object to reverse polarity, whereas other loads (lights, solnoids, etc..) don't care Your tractor hasn't been running backwards all these years has it? (joking)
/ JD 650 Battery Polarity Issue #5
What does a dc voltmeter say when put on the old battery? Has the polarity of the battery been reversed from its markings? If that's even possible....
/ JD 650 Battery Polarity Issue #6
My thought too. Maybe if dead and charged wrong it would no longer match it's markings.
/ JD 650 Battery Polarity Issue #7
How did you discover this?
I have read about batteries being reverse charged.
The battery posts are different diameters, so it isn't easy to reverse the cables accidentally.
/ JD 650 Battery Polarity Issue #8
Here's what I suggest.... find/beg/borrow a DVM (digital voltmeter) and set it to read DC volts. Put the red meter lead on what you *think* is the (+) positive terminal (marked) on the battery. Put the black lead on the other terminal, which should be the (-) negative (marked) terminal. The meter should measure +12.8 volts DC, or thereabouts. If you get a -12.8 volts DC on the meter, then the terminals have been marked wrong, or as mentioned it was reverse charged. NOT a good situation! I have owned two 750's myself, and as the other poster stated, they were both negative ground and the 650 should be similar.
/ JD 650 Battery Polarity Issue #9
I had a 1983 or so JD 750
It was a positive ground system
/ JD 650 Battery Polarity Issue #10
Your 650 is certainly negative ground.....and yes it sounds like the voltage regulator is toast also. Your alternator should put out 30 volts AC @ 2400 rpm to the regulator, (2 blue wires) On the regulator side of the attaching plug, black is ground, red is 12+ battery, green will swing + or - depending if it is charging or discharging and yellow is 12+ output to battery.
/ JD 650 Battery Polarity Issue #11
JD 650/750's came from factory negative ground on battery. Parts key # CH15195 Cable POSITIVE
/ JD 650 Battery Polarity Issue #12
Not to argue, but the 750 that I bought new was positive ground from the factory.
Still runs that way today although I don't own it.
/ JD 650 Battery Polarity Issue #13
I'm not trying to argue either but there are very,very few positive ground alternators and I think the one on the 650/750 isn't one of them. MIA10312
/ JD 650 Battery Polarity Issue #14
Yes, I realize there are very few. I found out the hard way on this unit when I hooked up a battery charger as you normally would - negative to ground and blew the fuse in the battery charger.
I think the one I owned was a 1983 and I owned it till 2008. Three batteries later all with positive ground and it's still going strong the last I knew. It was a JD 750
/ JD 650 Battery Polarity Issue #15
They are all negative ground.
/ JD 650 Battery Polarity Issue #16
that's why you hook up chargers according to battery polarity, and ignore chassis polarity....
/ JD 650 Battery Polarity Issue #17
Except every charger I've ever used, including my Snap-On professional charger, tells one to connect the positive cable first to battery '+' and then the ground cable to a solid chassis ground, NOT to the battery '-' post due to chance of sparking hydrogen gasses from the battery.... :confused3::confused2:
/ JD 650 Battery Polarity Issue #18
Which is exceedingly bad advise for a professional tool manufacturer (or anyone else) to give when there are plenty of vintage tractors and cars out there with postive ground electrical systems.
It pays to be smarter than the tools you work with.
/ JD 650 Battery Polarity Issue #19
i have to agree with rick.. that's bad advice.
if you are worried about a spark at the battery... leave the charger OFF when making cable clamp connections.. THEN turn it on...
/ JD 650 Battery Polarity Issue #20
Are you stating it's bad advice to attach ground lead from charger or jumper cables to a non-painted surface other than the ground post on the battery if battery is still installed in vehicle???
Status
