Shear bolt madness
/ Shear bolt madness
Okay, I have successfully changed the bolt and am operational again. Thanks to all that replied, every answer was helpful even if to just verify that I was already trying the right things. In the end, the bolt was rounded over on the front side so the advice about rotating it 180 degrees was the key. Even. Then. It took a moderate amount of force to drive it out. I did locate a pin punch but I'm not sure if that factored in at all. Here's some pictures cause I know we all love pictures.
Sent from my iPad using TractorByNet
/ Shear bolt madness #22
I have a Meteor SB51 blower that calls for shear bolts 6mm x 40 grade 8.8 and 1/4 x 1 grade 2. I was thinking about buying a package of shear bolts they sell for smaller snowblowers like MTD and Ariens. They look about the same size and have the grooves in the shank already. Do you think these will work?
/ Shear bolt madness #24
For my money, I buy the Kubota shear bolts for everything (impeller and fan) as IMHO it is a small price to protect the HST and other running gear . I buy a bag for each and keep them in my tool box along with the wrenches to change them. I keep a nail in the box to push out the sheared bolt.
/ Shear bolt madness #25
I don't understand why you guys are breaking so many shear bolts. In my lifetime I think I may have changed a half dozen on any piece of equipment. I can't remember the last one actually.
I looked at finding generic shearbolts when I first got the blower last year but with the grooves and the length of 2.25" I had no success and quickly decided that Kubota bolts were the way to go. I did not want to risk my warrantee to save a buck or two on a bolt.
/ Shear bolt madness #27
I don't think you understand the situation. The BX2750D snow blower uses special shear bolts which have a reduced diameter at the shear points as seen in this photo. This is a 2750D auger shear bolt.
The reduced diameters prevents a bur from jamming up the shank, in theory anyway. I have sheared 8-10 bolts with mine, auger and fan wheel, and have always been able to easily push the shank out with a nail. I use a nail because I think it's easier to find the old shank "feeling" around with the pointed head as apposed to the flat head of a 3/16" or 1/4" punch. The fan wheel hole cannot be seen without a mirror; it's back inside the shroud, so a good "feel" is necessary to find the hole/shank. So while you would not normally think of a nail as being a better tool in a shear bolt situation, I like it better than a punch in this situation.
Dean
Hi Dean,
A tip I learned here on TBN about inserting a new fan pin: If you look at the drive shaft from the front gearbox on the 2750D, you'll see a drilled hole just forward (towards the gearbox) of the fan, maybe an inch or so. The hole for the shear pin is in direct alignment with this drilled hole. So line up the hole for the shear pin fan with this drilled hole and the pin will push right in without trying to spin it around to feel for it.
-PK
/ Shear bolt madness #28
Hi Dean,
-PK
That is great info, Peter. Thanks for that. While I don't shear nearly as many bolts as I did before putting on new skids, I still do shear one occasionally and as you know the fan bolt can cause you grief. That tip will certainly help with that situation.
/ Shear bolt madness #30
Reason for shear bolt breakage here in Southern Maine is heavy wet snow and I think the cumulative effect on the strength of the bolt. Additionally, I have a sand/gravel/dirt drive that sometimes has a large stone that gets picked up as well as the occasional tree limb and chunks of ice. Before the ground freezes I plow the snow and get most of the loose stuff out of the way of the blower but there are always a few stones that seem to grow during the winter. Stay safe!
Last year was my first year with the blower and I learned many of the reasons for breaking a shear bolt the hard way, including picking up a loose field stone while clearing the walkway. Not recommended, by the way, makes a heck of a racket! This year I was resolved to put those mistakes behind me and was being real careful (I thought anyways) but I must have hit a chunk of ice buried in the 6" of powder. Guess that's just part of the charm of New England winters.
/ Shear bolt madness #32
If you look at your pictures you can see the drive shaft between the auger sleeve and the flange mounted bearing. What helps me with my blower is a center punch mark on the drive shaft and a corresponding center punch mark on the auger sleeve when a shear bolt is installed and intact. Then when the bolt shears I line up the punch marks and removal (and installation) is easier.
I was trying to think of some way to create an indicator for when this happens and your suggestion sounds like a good solution. Thanks!
/ Shear bolt madness #34
Yep. Thank you from me too.
/ Shear bolt madness #35
Built this for removing the pin in case pin gets frozen. Also acts as the drift pin to line everything up. Welded on 5/16 nut to heavy duty beam clamp, ground out bottom slot for broken piece to drop out.
/ Shear bolt madness #36
After all the reading about shear bolts, I ordered 20 of each today exactly as specified by MK Martin for my Meteor snowblower.
I googled one of the bolts and got to a company called BoltDepot in the Boston area. Prices are from 7 cents to 15 cents each.
There have been a lot of comments about various grades, and bolts that are threaded full length of the bolt. I do not want to substitute from OEM spec so now I have a supply. I have only broken a couple of the impeller bolts and they snapped clean so I will stick to what works.
/ Shear bolt madness #37
Good discussion on broken shear bolts, interesting how we all start off the same way:)
As a key point, we should insure that what ever bolt is installed ( should be no greater than grade 3 bolt) that the shank of the bolt covers both the driven and the drive hole surfaces completely. If bolt thread comes into contact with the holes in the driven component, the threads tend to elongate the hole sooner than the flat shank of the bolt would. I also bought these by the handful early on but now, for the first few snow falls, I set the blower skids lower so as to raise the cutting edge to about one inch high. This leaves a bit of snow which gets packed down over the gravel base and therefore no more blowing stones all over the lawn and no more broken bolts...
Dan
/ Shear bolt madness #38
Well, I use grade 5 long enough that there are no threads in the shear area.(threads make for a premature fail point)
Less than grade 5 won't sheer but rather bend+elongate b4 sheering making it hard to drive out with a drift punch.
I have even added a rubber sleeve to my drift punch as in the extreme colds my fingers go numb.
I don't want threads in that sheer area as they simply mess up the cutting action of the shaft to sleeve area. (experience talks)
About the only time I sheer is when a rock gets in there between the flighting and the body or the fan and shroud.
Last winter I sheered maybe twice and both times were due to the city plow inserting a sizable stone into my snow bank. Both stones were sort of tapered but other than a sheer bold no other damage.
/ Shear bolt madness #39
Hi Dean,
-PK
Is there a trick to this? I spent several hours, first alone, then with a friend who has several tractors, and we could NOT get the centre part of the broken pin out. We were trying to figure out our best option short of taking the blower off the tractor, because it's really difficult to mount when it's -17C or thereabouts (and no, we don't have a warm garage option of any kind....).
We can get a bit of grip on the hole from one end, but unfortunately it's the end with next to no room to manoeuvre. Pounding a pin through at the other end has accomplished nothing at all :(
Thanks if anyone has any advice!
/ Shear bolt madness #40
Any room for a drill from one end?
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
