Anyone have a good design for a protectove PTO cover?
   / Anyone have a good design for a protectove PTO cover? #1
jodebg
New Hartford, CT
Kubota B-2650
Would like to make a cover for the mid and rear pto's.
Any ideas? Thanks.
   / Anyone have a good design for a protectove PTO cover? #2
   / Anyone have a good design for a protectove PTO cover? #4
I thought all the Kubota's came with a simple rubber/vinyl slip cover. Mine all did. I imagine there is a part number?
   / Anyone have a good design for a protectove PTO cover? #6
If you are referring to a cover for the PTO splined power take off, I simply used a piece of poly pipe and a short piece of wire to hold it on. It's not fancy but it's cheap!!
Weedpharma
Kubota b7800.
The owner's manual shows a hinged c-shaped cover sitting above the rear pto shaft. Don't know if this was
original to this tractor and if I should consider replacing it? Also, looks as if it had a round shaft cover, as well.
Mission accomplished. While shopping in our local Big Lots store I came by a set of 4 heavy black plastic Keeper Bed Risers.
They fit great and completely cover the rear pto. Just drilled 2 small holes in each side and fastened with 2 black wire ties.
The price for a package of 4 is only $5.
Very sturdy and the way they are designed, they are out of the way of the PTO operation.
Need to hook up to the PTO, just cut the 2 wire ties and you are ready to go.
I will post a photo asap.
   / Anyone have a good design for a protectove PTO cover? #9
could you post a picture? It might help others.
James K0UA
Photos of the rear PTO cover
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
Yamaha (A55758)
Yamaha (A55758)
2021 VOLVO VNL740 TANDEM AXLE MID ROOF SLEEPER TRUCK (A57880)
2021 VOLVO VNL740...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
2021 Ford F-450 (A55973)
2021 Ford F-450...
