Anyone have a good design for a protectove PTO cover?
   / Anyone have a good design for a protectove PTO cover? #1
jodebg
New Hartford, CT
Kubota B-2650
Would like to make a cover for the mid and rear pto's.
Any ideas? Thanks.
   / Anyone have a good design for a protectove PTO cover? #2
   / Anyone have a good design for a protectove PTO cover? #4
I thought all the Kubota's came with a simple rubber/vinyl slip cover. Mine all did. I imagine there is a part number?
   / Anyone have a good design for a protectove PTO cover? #6
If you are referring to a cover for the PTO splined power take off, I simply used a piece of poly pipe and a short piece of wire to hold it on. It's not fancy but it's cheap!!
Weedpharma
Kubota b7800.
The owner's manual shows a hinged c-shaped cover sitting above the rear pto shaft. Don't know if this was
original to this tractor and if I should consider replacing it? Also, looks as if it had a round shaft cover, as well.
Mission accomplished. While shopping in our local Big Lots store I came by a set of 4 heavy black plastic Keeper Bed Risers.
They fit great and completely cover the rear pto. Just drilled 2 small holes in each side and fastened with 2 black wire ties.
The price for a package of 4 is only $5.
Very sturdy and the way they are designed, they are out of the way of the PTO operation.
Need to hook up to the PTO, just cut the 2 wire ties and you are ready to go.
I will post a photo asap.
   / Anyone have a good design for a protectove PTO cover? #9
could you post a picture? It might help others.
James K0UA
Photos of the rear PTO cover
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
2017 Ford F550 (A55973)
2017 Ford F550...
2008 CAT 305C (A53317)
