SilverJett
Looking into purchasing a new L6060. Also considering a 4720...but the design is very dated and the cab is cramped at best. My questions on the L6060:
-Installation of Trimble Autopilot/FMX - where is the hydraulic tank return located on the L6060? The Autopilot re-routes the steering hoses from the steering controller and diverts it through a control block, and needs to have a "tank return" in order to function. Looking through the online parts diagram doesn't show a dedicated port and I'd prefer not to go through the hyd fill port at the back.
-Will this tractor handle a JD 681 (81 inch) tiller? I've never had an HST tractor before - will the tiller "push" the tractor when operating or can the HST hold it back?
-Hydraulic capacity - various online specs do not match up - what is the actual GPM??
-Cruise control - is there a resume function? Can you set a "maximum speed"?
-Rear spur final drive...how does this compare to planetary?
-Cab dB - does anybody know how quiet the cab is?
-The L6060 does come with Cat I/II, correct? I know the 4720 does not
-Does it have a 12v 3 prong accessory outlet in the cab?
-Any common issues popping up with this new model? Tier 4 doesn't bother me at all. Have an M9960 and it's been flawless
Anybody have any pictures of an L6060 with the 13.6-28 Ag tires?
Thanks!
Thanks!
