Glow Plugs
/ Glow Plugs #1
NoTrespassing
Elite Member
East Central Illinois
Kubota 1999 L3710 HST FWA
Looking for answers,
1999 L3710
Should I be getting a glow plug indicator @ 60 degrees F on cold start up? I swear it used to but I haven't seen the indicator light this summer. If I have a problem I don't want to wait for cold weather to work on it.
Thanks,
Kevin
/ Glow Plugs #2
I'm pretty sure you should be seeing that glow plug light on cold start-up.Sounds like something is not right.This should bump it up for the "L" experts to comment.Good Luck!
/ Glow Plugs #4
With the engine fully warmed up, when I restart my L5030 the glow plug light comes on for about a second. It also always comes on with a cold start regardless of the outside air temp.
/ Glow Plugs #5
I have a 2008 L3940 with about 400 hours and have operated it from a low of 25 degrees to a high of 110 degrees. Every time I turn the ignition key to the first click the glow plug light comes on for about 1 to 2 seconds. When it is really cold it will come on for several seconds before goi g out.
More informative than the light is the loud relay switch I can hear click on when the key is turned and off when the light goes out.
It is a pretty good click noise. That is what I wait for before I try to start it.
/ Glow Plugs
To follow up on this thread, my glow plug is NOT working. I'm looking for suggestions on where to start trouble shooting. The only electronic tool I have is a multimeter.
/ Glow Plugs #7
The correct way is to use your meter on ohms resistance setting. take plug out of engine and check from body of plug to electrode where wire goes on. if reading is 5 ohms or less - then its good. If higher then 5-6 ohms or open, replace.
If anyone doesnt have a meter, then the poor mans method is use a car charger. Clamp black on body and touch the electrode where wire goes in and watch it start to glow. No need to do this for long and CAREFUL!!! its HOT!!! . you will need a safe surface to put it down on and let cool off completely before putting back in engine. Anything that doesnt glow is bad. Please let the plug become completely cold, not luke warm after testing with charger as metal expands and you dont want to enlarge the threaded hole to engine.
/ Glow Plugs #8
I personally see no reason to remove glow plug to check continuity.. I check glow plugs with an amp meter one wire on battery positive post and other wire on glow plug connection then look for a amperage draw.
/ Glow Plugs #9
A non contact ir temp gun also works, without taking anything apart
/ Glow Plugs #10
Check the output of the relay/timer/control box (I'm not sure how your model is set up) to see that it is feeding power to the glow plugs.
With the glow plugs electrically disconnected I'm guessing you should see something close to full battery voltage (Vdc) at the glow plug connector. Try to do this first, before pulling any glow plugs out - it's possible but pretty unlikely that all of the glow plugs would fail at the same time.
Rgds, D.
/ Glow Plugs
A very interesting thing happened today when I started the tractor for the first time in over a month. The glow plug indicator lit up, stayed on for about two seconds, and everything seemed to work perfectly. The outside air temperature was 40 F. I guess for now I'm not going to do anything but use it.
Does anyone have any idea why it would work now in cold weather when it hadn't come on all summer? Is this normal operation? I remember the same thing happening last year and I thought I had lost the glow plug then too until cold weather set in and it started working.
Kevin
/ Glow Plugs #12
OK, assuming this gplug timing is different than it used to be, I would:
1) Get a schematic for your model, that details the glow plug circuit. Post the schematic here if you can get one; that will help stir up more diagnostic comments.
2) Check the physical integrity of all the related wiring - harness, fuse holders, grounds, ignition switch. Take a close look at your battery terminals and cables. Any sign of corrosion or suspect connections, take apart, clean, re-assemble and coat with dielectric grease or your preference. I don't know what the implications of having a battery disconnected on your model are - I personally would be willing to disconnect a battery on a '99 tractor if it was mine, but don't want to create a false impression of knowledge I don't happen to have :laughing:.
3) Note on the schematic where the GP indicator light is being driven from. If it is on the output side of the GP relay, then perhaps the relay is going south on you. Assuming that the GP relay is the lower cost item (compared to the control module) consider getting a relay to test with. I just bought 2 for my truck (it takes 2) to have as spares from Crank and Charge off Ebay. Not sure if they do Ag stuff, but their prices are good and they give you a warranty.
crank-n-charge on eBay
Nothing against OE, If Kubota's price is not crazy for a GPR, that's the way to go.
4) You need to be able to compare to another similar tractor, or get ON timing vs. temperature specs from a Service manual to really know if the control module/timer is working properly. If everything else checks out fine, and you still seem to be getting very narrow or inconsistent ON timing for the GPs, then you may need a new control module.
Rgds, D.
/ Glow Plugs #13
Kevin
The glow plug timing circuit turns on the relay Depending on how Cold the temperature is... that is Normal.
/ Glow Plugs
The glow plug stopped working all together a few weeks ago. The electric fuel shutoff stopped working last summer. I had the place I bought the tractor from pick it up to work on it last week. It turns out the terminals in the fuse box had rusted from the back and they replaced that one holder with a seperate one. That fixed both problems. They also changed a couple hydraulic hoses on the loader and changed the oil and filters. I haven't got the bill yet.
/ Glow Plugs #15
Thanks for the update, and glad to hear it's fixed.
I more commonly see that type of fuse panel problem on road-going vehicles - do you do a lot of road travel, or otherwise deal with a lot of salt ?
I'm a fan of keeping electrical connections covered in grease or equiv. Looks messy to some people, but automotive wiring seems to be self-destructing at an even faster rate these days, so I'll keep my messy grease :thumbsup:.
Rgds, D.
/ Glow Plugs
It doesn't see any road use and no salt. It is 14 years old though and sits outside quite often. The bill was a little higher than I thought it would be, over $800. I probably could have done all the work myself for under $300 if I'd known it was the fuse box. Oh well, it's done, there's snow on the ground now and I'm glad it's fixed.
/ Glow Plugs #17
Amortized over 14 years, that's not too bad at all.
The Important thing is that you now have a solidly working tractor back ! :thumbsup::thumbsup:
There are some optimal greases to use (dielectric, etc.... somebody on here has a favourite one out of the Telecomm world.... just can't remember the name.......) , but IMO, even if you use nothing more than a basic lithium grease to coat 12volt connections, you are doing your vehicle a big favour.
If your relationship with Murphy is the same as mine, now that your tractor is back to 100%, you won't get much snow the rest of the Winter. Your neighbours will thank you !
Rgds, D.
/ Glow Plugs
Well...I went out to plow the 8-10 inches of snow this morning and the glowplugs didn't come on. It still started after extra cranking, luckily it was 34 F. out. I guess I'm going to have to call the dealer on Monday. I'm pretty disappointed considering I just sent them a check for over $800. I'm hoping to not have to pay transportation costs this time. Actually I'm thinking of trying to just get away with paying only for parts they put on it and hope they comp the labor. We'll see, I'm glad it started this morning or we'd be stuck on the property until I got it running.
/ Glow Plugs #20
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2022 EZ-GO ELITE...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
Takeuchi TL6R (A64126)
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
